[SUMMARY] Gaming Monitor Recommendations
jjlin1972
Worth it to go IT show next weekend if shopping for new 32 inch high end 4K gaming monitor? Saw 322urx have 100 sgd discount.. but still expensive
Booomz
It doesn’t force you to run the pixel refresh. Usually by default 1 hr after standby or off , so when you stop using the pc for a prolonged period.
Honestly 3rd gen panels really don’t need to baby. Auto hide taskbar and something like wallpaper engine or full black wallpaper is more or less enough.
More importantly shorter display off time in power saving options, 3-5 mins max, which some might find annoying.
zenricz
Any recommendation for 27 inch 1440p IPS monitors? budget around $500, saw the KTC H27T22C but not sure if its any good
PsyClick
are all qd-oled 34" ultrawide stuck at 110ppi?
any suggestions for something 160ppi onwards?
SKinny86
I was using a curved screen, now changing to a flat screen made my vision weird! OMG I thought my monitor kena bent 😅
hyperfuse
same issue when i was using the 34 inch AW3423DWF and now onto the LG dual mode monitor. mine is the one with pixel sound. i thought the screen was concaved. looks flat to me only after a month of usage.
anyway overall, i really love the dual mode as its suit my use case scenario.
