Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    202
waterballoon
gapboy
i always use camera rings mah, then just now i wanna change color, knnnnnnn 'both' come out together
:ROFLMAO:
I never use all my phones ... It will give bad image quality as mentioned by many.. Maybe that's why people are complaining image is bad for them on s25
frizee
for me still ok i not that particular about it but now gg already :D
kashix
Came across this tip/trick on Reddit. I tried it and it is working so much better now. When registering your finger/thumb. Do alternate.
1st scan) right thumb
2nd) left thumb
3rd) right
4th) left
Repeat until the setup is completed.
Doesn't make sense but now when with dry thumb, I can unlock relatively easier than before. I had 3 scans of the same right thumb previously and still having intermittent unlock issues with dry thumb.
Finally no need to lick my finger/thumb to unlock. So happy!
twosix
2nd) left thumb
3rd) right
4th) left
I did this before on my s23u. After some time, the scanning will be a hit or off thingy again.
Now I scan my thumb 1by1, making sure to scan all areas. So far so good, less login misses now.
rharish_21
i always use camera rings mah, then just now i wanna change color, knnnnnnn 'both' come out together :ROFLMAO:
May i know which camera lens protector you used and tried to change? i am using the spigen one and every time i hear these sort of stories, i am feeling phobia.
