- Sep 16, 2018
1) Why do you want 10Gbps when 5Gbps/6Gbps plan offer much better value?Just read the posts on routers and mesh systems. For 10gbps plans, should I go for M1 Archer BE805, M1 Asus BT10(x2) or Starhub EB810v? I know that BT10 is not popular here. If Singtel is offering BE85 it will make my job easier.
Take note 10Gbps plans by local consumer ISPs will have the max speed at about 8.2x Gbps due to XGS-PON technology limitation.
2) In case you really want to have 10Gbps, you can continue reading.
SingTel is offering HB810 which has basically the same spec as Deco BE85 but with TP-Link EasyMesh and not Deco Mesh.
Take note SingTel is using ONR and the HB810 is configured in AP mode by default, wasting the CPU power of HB810. If you only care about wireless performance, then this does not matter.
Asus ZenWiFi BT10 two pack is still popular, it will be the best option if you want a mesh solution, as AImesh is similar to Deco mesh in terms of maturity. Asus AImesh and TP-Link Deco Mesh are both more mature and better than TP-Link EasyMesh as a mesh technology. ZenWiFi BT10 is usable but not that great as a single router because it has the weakest CPU among all the routers in this discussion.
For M1 10Gbps plan, in reality nobody should select Archer BE805 anyway, since ZenWiFi BT10 two pack has much higher resale value. If you like Archer BE805, then you can even sell the two ZenWiFi BT10 for about S$660 and buy a new Archer BE805 for about S$300.
EB810v has the best HW spec (slightly better than HB810 and Archer BE805) but there seem to be quite some FW issues reported in this forum and TP-Link seems to slow in fixing the problem as it is a service provider model.
3) My recommendation will be M1 10Gbps plan if you die die want to choose among SingTel/Starhub/M1 10Gbps plan.
4) But I will recommend M1 6Gbps plan with free Archer BE805, at S$34.90 per month, it beats the value of SingTel/Starhub/M1 10Gbps plan.
