AngelRomeo
- Sep 14, 2024
should be can buy, but display sets not sure. from what i observe they dont normally put up display sets for the latest mac if the design are the sameWould it available on 12 march at Apple store ?
I'm sure display set would available for blue color.should be can buy, but display sets not sure. from what i observe they dont normally put up display sets for the latest mac if the design are the same
The base M4 MBA sells for $1349 with education discount.No display at orchard yet. But m3 air selling 1349
at this price, really is just top up abit to get the M4 MBA.No display at orchard yet. But m3 air selling 1349
That's the reason why both products are of similar price range.Did you know: M4 CPU in the M4 Macbook Air = Ipad Pro 13" 1TB/2TB?
Hence buying this M4 Macbook Air is like buying Ipad Pro 13" without the touchscreen + inking + 5G + HDR OLED, but with multitasking MacOS instead.
This seals my decision: Buy Ipad Pro 13" and Macbook Pro 16.That's the reason why both products are of similar price range.
But i will definitely pick the MBA over the ipad. One is a reliable sleek workhorse, the other is more of multimedia consumption and need a lot of add-ons to use as a computer.
Actually Mac OS is not meant for touch screen.This seals my decision: Buy Ipad Pro 13" and Macbook Pro 16.
Macbook Air / Ipad Pro can actually be combined to a single product, but Apple refuses to do so, hence I shall not reward Apple for this anti-consumer decision.
A simple solution is allow Ipad Pros to dual boot MacOS and IpadOS.
Or simply enable proper mouse control within IpadOS.
Will it be as good? Wonder whether this m4 air can win the m1 MacBook Pro or notOr a Mac Mini for home, and a Ipad Pro 13 for mobile productivity and leisure?
The new oppo n5 can use macbook touchscreenActually Mac OS is not meant for touch screen.
In iOS and iPadOS, to close the app, you just need to slide up or use the five finger squeeze (in ipad). But it is not precise so for certain apps, the precision of the cursor of a mouse is preferred.. such as excel, CAD drawing, design, etc...
In mac OS, you have to use command Q to close the app or move your mouse cursor and click x (which technically doesn't really terminate the app). So you can see that Mac OS is more of mouse controlled OS because the apps are designed to be manipulated this way. And also, a mac can be big so a pure touchscreen is tiring to use.
Having touchscreen is one thing. It's the user interface.The new oppo n5 can use macbook touchscreen
Been using the MacBook Air M4 the past few days.
Sky blue
4P6ECPU /10 GPU
512gb storage
Bought for $1649 using education discount.
