- Sep 16, 2018
If you don't mind elaborating, what needs do each serve better?
I'm still on the fence as I see from catching up on the threads (this one and your other very useful ones) that the SH plan is highly recommended.
What attracts me to the SH 5Gbps plan:
The only thing holding me back from cancelling the ST 3Gbps Enhance plan:
- Saves me $10.15/mth ($39.70 vs $29.55)
- ONT instead of ONR
- 5Gbps > 3 Gbps
- 2 x TP Link HB611 routers, so I can place one in my bedroom to eliminate dead zones/improve WiFi strength.
Are there any other considerations I'm missing?
And if you were in my shoes, which would you pick?
1) I will choose Starhub because of the ONR vs ONT thingy. But that is just me. I do not recommend new users to sign up with Singtel because of ONR.
I understand most average users may not be bothered with ONR, but then it limits the choice in the future if the average users become a power user.
Even if we ignore ONR vs ONT thingy, you can compare in the following way.
Starhub S$29.55 per month --> ONT + HB710, if one HB710 is not good enough for wireless coverage, then add one more HB710 at S$192 from Starhub, effective price is S$37.55 per month with two HB710.
HB710 (dual 10G ports, triband BE18000) is better than HB611-SGST (dual 2.5G ports, dual 1G ports, triband BE11000).
Starhub ONT + 2 x HB710 (S$37.55 per month) > Singtel ONR + 2 x HB611-SGST (S$39.90 per month)
Even if adding digital voice (Starhub digital voice is not free, S$2.14 per month), the price is more or less the same but Starhub bundled router is better.
Starhub ONT + 2 x HB710 (S$37.55+S$2.14= S$39.69 per month with digital voice) > Singtel ONR + 2 x HB611-SGST (S$39.90 per month)
Only catch is that HB710 has less LAN ports, so if you want the LAN ports in the rooms to be functional, then you have to add a 2.5G/10G switch (about S$100) or at least a 2.5G switch (at about S$50).
10G capable switches:
https://forums.hardwarezone.com.sg/...and-switch-rj45-version-no-sfp-ports.7072646/
Hasivo S600W-4GT-2XGT-SE, RMB 499 listed, quad 2.5G ports, two 10G RJ45 ports
Hasivo S600W-4GT-2SX-SE, RMB 219 listed, quad 2.5G ports, two 10G SFP+ ports --> you can use this as a 2.5G switch first, yet with possibility to add 10Gbe support with 10G SFP+ to RJ45 module (about S$20).
Hasivo S600W-4GT-2XGT-SE is probably the cheapest you can find. You should look at the price at Taobao 海思视讯 shop and it is only at RMB 699 listed price --> now about RMB 499 in Feb 2025.
Hasivo S600W-4GT-1SX-1XGT-SE, RMB 399 listed, quad 2.5G ports, one 10G RJ45 port and one 10G SFP+ port
【淘宝】退货运费险 http://e.tb.cn/h.TagwCPy1xtfft6L?tk=OUoQ3qhNKyt MF3543 「hasivo 2.5G万兆上行POE轻网管交换机企业办公猫棒VLAN猫棒网管型」
点击链接直接打开 或者 淘宝搜索直接打开
2) For existing Singtel users who have no issues with ONR, then it is a bit hard to choose. I usually recommend existing users to try to recontract, unless you got issues with existing ISP or the other ISP has got much better offers. But in this case either way is okay. I will lean more toward recontract with Singtel because of the hassle of swtiching to another ISP.
