- Sep 16, 2018
Floorplan uploaded here - https://ibb.co/995vHZ7C.
Modem and router both at the same location in living room. No LAN ports in rooms. Using HomePlugs for PCs in the study room instead.
It is an old RT-AX88U. It had issue reaching my master bedroom & its toilet of my 5RM point block previously as well. So thought I needed a stronger one, or a second one nearer the bedroom.
For BE230, I meant TP-link's EasyMesh, so had the impression that my option was to buy a better model from either TP-Link or ASUS, and use the respective lousier one as node.
Thanks!
Maybe your placement is also a problem, try to put your existing RT-AX88U in a high place to see if that helps. If possible, move it a bit up towards the dining area.
Since you do not have LAN ports in the rooms, if you need to use a mesh solution, you have to use wireless backhaul. Best for mesh with wireless backhaul is to use triband mesh solution. But neither RT-AX88U nor Archer BE230 is triband.
Since you already have the RT-AX88U, one option is to get TUF-AX6000 as the main router, then use the RT-AX88U as AImesh node. Both are dual band router so not the best for mesh with wireless backhaul, but it may well work. You have to carry out experiment with the placement of the RT-AX88U. In this case, you can sell the Archer BE230.
Or you can get another Archer BE230 (less than S$100) and then use two Archer BE230 based mesh solution.
If you want to use triband mesh for the best performance, you can check with M1 whether they still have the PWP offer for Asus ZenWiFi BT10 two-pack for S$21 x 24 = S$504. In that case, you can sell both the Archer BE230 and RT-AX88U.
