Is Singapore sitting on a tectonic plate?
hotamp
All these acts of god, natural disasters, sit or no sit, the whole earth is inter connected, when the time comes cannot siam one also will kena one lah. :p earthquake in indonesia can also cause a tsunami and sink sg.
Visor9999
Means staying high floor or low floor better for earthquake?
carlongerdidu93
https://en.wikipedia.org/wiki/Plate_tectonics
[deep seek ai]:
For Singapore, the nearest tectonic plate boundary is the Sumatra Fault, roughly 600 km away. The Sunda Trench is about 1,200 km south.
Ancient fault lines discovered in Yishun & Jurong, explained
https://mothership.sg/2018/01/fault-lines-singapore/
Ancient fault lines that are 200 million years old have recently been discovered in Jurong around Pioneer road, and along Sembawang road in Yishun.
Ancient fault lines are geological fractures that formed during past tectonic activity, often long before the present day, and can still influence the landscape and seismic activity of an area
Other fault lines in Singapore had been found in a few other places years back:
  • Tanjong Gedong
  • Murai
  • Pasir Laba
  • Nanyang
  • Seletar
  • Pepys Road
  • Henderson
  • Nee Soon
  • Ama Keng
Whats with the new ones?
The new ones, discovered by SP Group, were discovered in Jurong around Pioneer road, and along Sembawang road in Yishun.
There are about 10 "new" fault lines, which were discovered progressively between 2014 and 2016.
For example, one of the faults is seemingly near the Sembawang Hot Spring. Maybe this could be a clue to why the spring formed?
The Faults in Our Yishun. Fault locations are estimated. Image adapted via Google Maps.
The Faults in Our Jurong. Fault loactions are estimated. Image adapted via Google Maps.
Oh no! Will we have earthquakes then?
Not really.
However, it is known that Singapore may be somewhat affected by a massive tremor or aftershock, as we did in 2004, 2007 and 2012.
As these fault lines are not so much due to active seismic lines or tectonic plate activity, disaster flick fans can chill.
We can't discount the fact that if a strong tremor happens, low damage can occur to structures, which includes windows breaking.
Then why should we care about the fault lines?
These fault lines not only caution workers where to safely install the cables, underground caverns and other facilities, but also allow them to discover cool things.
For example, metatuff rocks, which are essentially compressed from volcanic sediment and ash. It's 200 to 250 million years old.
Maybe to the untrained eye, it's just like any rock, but to researchers and geographers, this could be a historical record in the ground, telling us about how Singapore may have been formed -- since the ash settled there from volcanic eruptions in the region a long time ago. Active volcanoes are present in Indonesia and the Philippines.
Along with the faults, it's a peek into our geographical story, spanning eons.
Are we safe, though?
For the most part, yes.
Our buildings are built to withstand tremors, thanks to the Building and Construction Authority's set of building codes and guidelines that were established in 2013.
zoossh
Low rise
Away from coast
If possible check constructed by which country
Dun think you can choose the floor most of the time?
Visor9999
Low rise
Away from coast
The lower floors storeroom have to survive the crushing weight of collapse building before rescue workers come
