Asus WiFi 7 and WiFi 6E routers
With SSH access and installation of ENTWARE, you can use a lot of Linux command inside Asus routers.
Asus router Entware installation guide, with stock Asus FW.
https://github.com/Entware/Entware/wiki/Install-on-ASUS-stock-firmware
Some useful tools: ping, ip, ifconfig, iptables, nslookup, traceroute, tcpdump, wget, curl, etc.
https://forums.hardwarezone.com.sg/...ubleshooting-the-network-performance.6641164/
Example:
Bash:
xiaofan@TUF_6500-5020:/tmp/opt/root/ookla# ./speedtest -s 13623
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     1.91 ms   (jitter: 0.10ms, low: 1.85ms, high: 2.09ms)
    Download:  2370.13 Mbps (data used: 1.2 GB)
                131.91 ms   (jitter: 69.91ms, low: 1.89ms, high: 828.49ms)
      Upload:  2369.23 Mbps (data used: 1.8 GB)
                  2.09 ms   (jitter: 0.84ms, low: 1.10ms, high: 3.95ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/bb4ba8da-205e-47c2-aa1d-daef4c0a3091
xiaofan@TUF_6500-5020:/tmp/home/root# cat /sys/class/thermal/thermal_zone0/temp
77000 (CPU temp at 77 degree C)
xiaofan@TUF_6500-5020:/tmp/home/root# cat /sys/class/thermal/thermal_zone1/temp
76000
xiaofan@TUF_6500-5020:/tmp/home/root# cat /sys/class/thermal/thermal_zone2/temp
77000
xiaofan@TUF_6500-5020:/tmp/home/root# cat /sys/class/thermal/thermal_zone3/temp
77600
xiaofan@TUF_6500-5020:/tmp/home/root# cat /sys/class/thermal/thermal_zone4/temp
77300
xiaofan@TUF_6500-5020:/tmp/home/root# nvram show | grep dns_ping
dns_ping_state=
dns_ping_tbl_name=
dns_ping_db_path=
dns_ping_list=<114DNS>114.114.114.114<114DNS>114.114.114.115<Ali DNS>223.5.5.5<Ali DNS>223.6.6.6<Baidu DNS>180.76.76.76
size: 59092 bytes (63788 left)
xiaofan@TUF_6500-5020:/tmp/home/root# nvram show | grep dns_probe
dns_probe=0
dns_probe_timeout=1
dns_probe_host=www.baidu.com
dns_probe_content=*
xiaofan@TUF_6500-5020:/tmp/home/root# dig dns.google.com
; <<>> DiG 9.20.0 <<>> dns.google.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 48841
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;dns.google.com.                        IN      A
;; ANSWER SECTION:
dns.google.com.         675     IN      A       8.8.4.4
dns.google.com.         675     IN      A       8.8.8.8
;; Query time: 10 msec
;; SERVER: 192.168.18.1#53(192.168.18.1) (UDP)
;; WHEN: Sun Apr 06 04:58:16 UTC 2025
;; MSG SIZE  rcvd: 75
xiaofan@TUF_6500-5020:/tmp/home/root# traceroute dns.google.com
traceroute to dns.google.com (8.8.8.8), 30 hops max, 46 byte packets
 1  OpenWrt.lan (192.168.18.1)  0.592 ms  0.375 ms  *
 2  bb115-66-xxx-254.singnet.com.sg (115.66.xxx.254)  1.914 ms  1.792 ms  1.830 ms
 3  165.21.193.22 (165.21.193.22)  2.806 ms  2.403 ms  1.706 ms
 4  165.21.193.21 (165.21.193.21)  2.398 ms  1.708 ms  2.073 ms
 5  165.21.138.245 (165.21.138.245)  5.280 ms  2.468 ms  2.648 ms
 6  SN-SINQT1-BO403-ae1.singnet.com.sg (165.21.138.85)  1.878 ms  1.560 ms  1.680 ms
 7  74.125.146.120 (74.125.146.120)  2.608 ms  3.136 ms  2.588 ms
 8  *  *  *
 9  dns.google (8.8.8.8)  3.229 ms  2.669 ms  2.972 ms
xiaofan@TUF_6500-5020:/tmp/home/root# traceroute6 dns.google.com
traceroute to dns.google.com (2001:4860:4860::8888), 30 hops max, 24 byte packets
 1  2400:d802:de2:xxxx::1 (2400:d802:de2:8900::1)  0.564 ms  0.482 ms  0.275 ms
 2  2400:d801:4001:611:: (2400:d801:4001:611::)  2.369 ms  1.897 ms  1.694 ms
 3  2001:c20:3c00::6 (2001:c20:3c00::6)  2.378 ms  2.700 ms  2.344 ms
 4  2001:c20:3c00::7 (2001:c20:3c00::7)  1.801 ms  2.162 ms  1.790 ms
 5  2001:c20:0:3::35 (2001:c20:0:3::35)  2.088 ms  10.962 ms  2.099 ms
 6  2001:c20:0:3::a (2001:c20:0:3::a)  2.250 ms  2.149 ms  1.738 ms
 7  2001:4860:1:1::2606 (2001:4860:1:1::2606)  2.076 ms  2.173 ms  2.337 ms
 8  2404:6800:8341::1 (2404:6800:8341::1)  1.920 ms  2.280 ms  2.410 ms
 9  dns.google (2001:4860:4860::8888)  2.326 ms  2.571 ms  2.254 ms
xLioNx
Hi there,
I am looking to setup something similar next year when my SH contract will be over. Can I check if you are using the RJ45 WAN/LAN point in the BE88U or SFP+ port to connect to the ONT? If you are using the SFP+ port, can you advice what is the transceiver you are using to do so, as I understand the ONT that Starhub provided is RJ45 only.
Hi hi sorry to reply u so late. I connected it into the 10G RJ45 port. Did not use the sfp+ port
I tried, connecting the starhub ONT into RJ45 WAN/LAN 1 or the 10G port is, both also can connect to starhub ISP network.
xLioNx
Try this, go to WAN menu and change from Auto Detect to the specific port you are connecting to Starhub ONT
Just sharing for those who bought/are thinking of buying the china version BE88U , this method worked for me!
Managed to resolve my china BE88U connection issues by designating the WAN port. Router no problems now
For BE6500, if you are setting region to AU, will it open more channel options?
No.
Asus TUF-BE6500 China version seems to be the only Asus China version router to have this problem -- only CN and AU region settings available.
I was hoping the FW updates will sort out the issue but so far no FW updates yet.
On the other hand, it is not a real problem for most users.
wuliaoji
Hi Xiao Fan and community lads.
Will be re-contracting with Starhub ( haven't firmed on 3gb or 5gb, don't know what's the huge difference), and need some help for router / modems.
I stay in a 3 storey landed and router is currently on the 2nd floor living room, with a direct land line to my desktop in my room. There are 3 google wifi 5 satellites through the power plugs.
Don't have a NAS and do some casual gaming, but mostly televisions and phones are hooked up. Not content creator either.
Any advice is greatly appreciated.
Thank you very much!
Do you have LAN ports in all three floors? This is the number one question.
What is your budget? This the number two question.
Last question will be about expectations. When you say you have three Google WiFi 5 satellites through the power plugs, what do you mean by power plugs? Using Power Line adapters? Or just wireless backhaul? The performance should be quite bad with wireless backhaul. How satisfied are you for the current wireless performance?
wuliaoji
I only utilise active LAN ports on the 2nd floor, 1 to the router and 1 to my computer.
Honestly, I'm also looking at value, as an upgrade from Wifi 5, will need your guidance. With my basic understanding, was considering the XT8, even though it was wifi 6 and may not be suitable for Starhub Wifi7.
After googling, I meant wireless backhaul. The two satellites were used on the 1st and 3rd floor to expand the wifi reach, although it is not the best. There is also one satellite on the 2nd floor opposite the router to expand that front as well.
Current approach gives me access to internet, albeit a bit slow. I think it's time to upgrade the package, or at least maintain the cheap package, but with a new router and satellites to improve the connection.. Although the current package is 1gbps.
Your best bet may be M1 6Gbps new user offer at S$34.90 per month, you can top up S$12 per month for a pair of ZenWiFi BT10. Then you can get another two Asus ZenWiFi BT10 at about S$504 PWP offer from M1 (you need to check if that is possible or not).
Starhub has removed the 5Gbps offer at S$29.55 with free HB710 a few days ago. But if you want to continue with Starhub, you can go with Starhub 3Gbps offer at S$29.55 (with free HB410), you can get four HB710 from Starhub at S$192 x 4 = S$768. In this case, you will be using TP-Link EasyMesh, which is not as good as Asus AIMesh or TP-Link's own Deco Mesh.
4 nodes of HB710 or 4 nodes of ZenWiFi BT10 will be much better than your four nodes of Google WiFi.
wuliaoji
Thanks for your suggestion and guidance.
Have checked online and realised that BT10 is insanely expensive through online retailers, for some reason that is unknown to me. Would you happen to know of an alternative to BT10 from Asus? Slightly trusting Asus more than a TP link.
I've also checked the M1 option and think that for a set of BT10, it would be 56.09 / month for 24 months. Not sure of the PWP option.
I'll have to go check on the Starhub option, as it is bundled together w TV and etc, although slightly hesitant on HB710.. Good if anyone has a review on this.. Will only be selecting 1 main router and 2 satellites, think it would be sufficient..
M1 6Gbps with a set of ZenWiFi BT10 --> S$46.90 per month. M1 gives very good discount for Asus ZenWiFi BT10. M1 website may be confusing but you need to take note of the sentence highlighted. The final pricing will only be shown in the checkout page.
https://shop.m1.com.sg/fbb/plans-bundles/fbb-plan?plan=HOMEPAC_6GBPS_24
With ONT
HomePac 6Gbps
$34.90/mth
This plan comes with:
$34.90/mth only applicable for new sign up
For recontracting customers it will be $47.90/mth (U.P. $95/mth)
24 mths HomePac 6Gbps
Choose 1 for free:
ASUS RT-BE92U (worth $399)​
TP-Link Archer BE805 (worth $799)​
Or top up $12/mth for ASUS ZenWiFi BT10 (pack of 2, worth $1,299).
Note: Final discounts for router, where applicable, will be calculated at checkout. While stocks last.
Free registration (worth $61.04)
Free ONT Activation for all time slots (worth up to $123.41)
Free Home Fixed Voice Service
Free 24 mths Mobile Broadband (Bespoke SurfValue)
Note: If you plan to move your address by June 2025, we recommend signing up for our 1Gbps or 2.5Gbps plans.
xonix
Check carousell if you are really into BT10 ;)
wuliaoji
With ONT
HomePac 6Gbps
$34.90/mth
Choose 1 for free:
Thanks for the info, will definitely look at it.
In the event I retain as a Starhub user, is there another Asus router / satellite that you can recommend?Or is the TP Link ones worth considering.
Surprisingly, the retailers v Carousell price for BT10 is insanely different........
Nothing beats the value of Asus ZenWiFi BT10 in the open market from Asus, especially you have to use wireless backhaul.
BTW, Carousell prices for two Asus ZenWiFi BT10 units are also dropping below S$700 (dumped by M1 users). Take note Asus retail pricing is insanely high at S$1299.
If you want to stick with Starhub, nothing beats the value of HB710 since you need to use wireless backhaul.
wuliaoji
Thanks for the advice, I do like Asus quite a bit, heard it's more long lasting than TP Link.
Will hope that SH can get this into their offers, especially since I lost the bandwagon for the 5gbps at a cheaper rate..
If not, I may go with what you mentioned, having 2 HB710 as satellites, but get an archer to be the main router. Maybe it could be a HB810 as well, depending on price.
Happy to hear your thoughts.
kenho_23
I just got A CN unit of TUF-BE6500. I set this as an AI Mesh node with ethernet backhaul with local BE6500 router which I got from MyRepublic. I am happy to report that they both are working well together and my dead zone issue seems to have disappeared.
gundamkitten
Asus ZenWifi ET12 Pro firmware update
the replacement for the March 2025 firmware update that got pulled is now available as of April 17th 2025.
ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.6.102_36597
Version 3.0.0.6.102_36597
50.96 MB
2025/04/17
SHA-256 :9E20908C366F192FD651BAC1AACF567428F1B07E34AF71E5A5654E255F1F0ABC
1. Fixed the UI issue in Chrome.
2. Fixed client binding issues in Mesh scenarios.
3. Enhanced input parameter handling techniques to improve data processing stability and system security.
4. Enhance system access control mechanisms.
5. Improved system stability and security by fixing a kernel integrity validation issue.
*Do NOT downgrade the firmware on any mesh device (router or node).
Due to enhanced security mechanisms, both the router and node must be upgraded together. Downgrading may result in a mismatch of security protocols between devices, causing the mesh connection to fail.
