Long weekend bo liao, reproducing flare with my Olight torch, TPU casing removed..
1 inch sensor
The one inch sensor flare pattern, the "straighter" edge is where the light source is from.
* In this little experiment the flare shown above was neither attenuated nor enhanced when my cheapo TPU casing was reinstated.
* Roughly happened when light source approaches the edge of about 110-120 degree fov. Guesstimated based on my kid's school protractor ..
* The flare cannot be blocked if the 67mm rim were to be raised like a lens hood by about an inch. ( By the time a hood is tall enough for 1 inch sensor, the 14mm wide sensor would have vignetted++ esp at the non flash side. )
Of course angle of flare changes with position of light source.. in this case below taken not too long ago. From my little table top experiment this funky flare pattern would disappear if I angulate the camera ever slightly towards the light source and converting it slightly to a more veil or amorphous streak type flare.. but at spur of the moment it impractical la.
Ultrawide
The ultra wide at 14mm is almost free of such discrete flare patterns, the very most tiny barely perceptible blurred light streaks which might not be immediately visible in bright well exposed pictures.
HP9 Periscope
The flare at 100mm, likely the HP9 periscope sensor.
Not very sharply shaped except a hazy bluish loss of contrast/sharpness/details
Didn check for the 70mm floating tele which is also for macro since that angle of lighting is unlikely to manifest in macro shooting..
Take home -
Nothing to worry about.
Took me abit of time to reproduce the flare, it is
uncommon and flares happen even with high end camera lenses, though we do hope manufacturers can at least make "beautiful" flares that can in a way value add compositions.
Flare from a modern Zeiss lens for digital sensors.
