BE92U speed up to 9700 mbps. tp-link BE805 has 19000mbps. So obviously tp-link has better feature than asus.I just bought the Asus RT-BE92U last week from Shopee Sales. My home broadband is using M1.
Wifi keeps disconnecting. Googled and found many complained about disconnection too. Have not have the time to troubleshooting. Maybe this weekend.
I've only started monitoring BB prices since my current contract is expiring in a month. Would it be right to say that M1 current offer of 6Gbps at $35.90 with the free BE805 is the best value plan now? I also saw the 3Gbps at $32.90 with BE230 and able to sign up online (while the 6Gbps requires a visit to M1 Shop).
I am on 1Gbps currently and don't really need anything more but it is actually difficult to find a no-frill basic BB plan for user like me. I could even continue to use my existing wifi router if the basic cost is low enough.
they wont touch non-m1 without the package routers i am quite sure. You can set it before hand and plug and play.Anyone has any experience with, or at least knows if … on the installation date, you give the M1 guy a router that is not 1 of those supplied by M1 e.g. you took the free low-end router but you bought an EB810V elsewhere … will they help set it up?
I’m okay with setting it up myself, but this is at my mother’s place and installation is on a weekday during office hours and the earliest I can be there to set it up myself is the next day before work … hoping to be able to avoid downtime for my mother.
Usually they wouldn't bother, but if it's for elderly, no harm asking for assistance and they might probably help since you mentioned it's for your mum's place.Anyone has any experience with, or at least knows if … on the installation date, you give the M1 guy a router that is not 1 of those supplied by M1 e.g. you took the free low-end router but you bought an EB810V elsewhere … will they help set it up?
they wont touch non-m1 with the package routers i am quite sure. You can set it before hand and plug and play.
Hmm if I set up the EB810V but currently it’s the M1 ONT for 1G (i.e. before they come to change the ONT for the 6G plan), I can still plug the 1G ONT to the EB810V’s WAN port right? Just that it will be running 1G? Then when they come to replace with the 6G ONT just connect to it?Usually they wouldn't bother, but if it's for elderly, no harm asking for assistance and they might probably help since you mentioned it's for your mum's place.
assuming this is the existing setup with 1Gbps:Hmm if I set up the EB810V but currently it’s the M1 ONT for 1G (i.e. before they come to change the ONT for the 6G plan), I can still plug the 1G ONT to the EB810V’s WAN port right? Just that it will be running 1G? Then when they come to replace with the 6G ONT just connect to it?
If so then I’ll just go do it over the weekend, less headache about whether they will or they won’t.
Right now before they come change out the existing 1G ONT with the 6G ONT, this 1G ONT is still hooked up to the existing AX router.assuming this is the existing setup with 1Gbps:
M1's ONT <-> EB810V's WAN Port <-> Internet/WiFi already OK
then during the 6Gbps installation day:
M1's ONT <-> EB810V's WAN Port <-> Internet/WiFi should be OK
i believe the crucial part is to ensure your 1Gbps works fine with the EB810V first.
so that during the installation day, the Engineer just swap the ONT & plug to your EB810V
should be no issues, but you need to setup the EB810V with the 1G ONT firstRight now before they come change out the existing 1G ONT with the 6G ONT, this 1G ONT is still hooked up to the existing AX router.
There shouldn’t be any issues setting up the EB810V to run on the 1G ONT, should there?
Yes, as what @HiHelloBye shared, setup your EB810v with your 1G ONT first, then when M1 comes, just have to plug the new 6Gbps ONT to your EB810v and should be working fine.Hmm if I set up the EB810V but currently it’s the M1 ONT for 1G (i.e. before they come to change the ONT for the 6G plan), I can still plug the 1G ONT to the EB810V’s WAN port right? Just that it will be running 1G? Then when they come to replace with the 6G ONT just connect to it?
Hi Guys, need advice.
Now on starhub 1gb, up for renewal. Best promo seems to be the m1 6gb. But I'm using netgear rbr750 (basement) + 3 (each level 1) satellites (backhaul) and have Netgear Armor till 2026 Sep.
If i proceed with the M1 6gb, what's the best way forward? How much are wifi7 satellites that are compatible with the be805?
go for it...trying to validate my point. if i intend to get BT10 pack, would it actually make sense to go with 10GBps plan @ 50 bucks per month? i have the offer @ 32.90 pm for 6GBps plan, for BT10 i need to add 12 pm, which the package comes to 45 pm. so i effectively pay 5 bucks for 4 gbps, not that i will fully utilise the speed but for 5 bucks to futureproof, i think i can afford that. any issue with my logic?![]()
Hello, did you apply any -15 voucher for the 10gbps plan?trying to validate my point. if i intend to get BT10 pack, would it actually make sense to go with 10GBps plan @ 50 bucks per month? i have the offer @ 32.90 pm for 6GBps plan, for BT10 i need to add 12 pm, which the package comes to 45 pm. so i effectively pay 5 bucks for 4 gbps, not that i will fully utilise the speed but for 5 bucks to futureproof, i think i can afford that. any issue with my logic?![]()
the voucher for 6gbps is $15, and voucher for 10gbps is $13 lol. not sure why got two categoryHello, did you apply any -15 voucher for the 10gbps plan?
$48.90?
i see.the voucher for 6gbps is $15, and voucher for 10gbps is $13 lol. not sure why got two category
