Qualcomm Snapdragon 8 Elite series
bakayarou
Qualcomm has successfully made this chipset very well, it made the phones speed very comparable with iphones.
So far, noticed Xiaomi 15 Ultra & OnePlus 13 phones are the fastest android phones now...Because it can load Real Racing 3 game faster than iphone
limmk
Last year, Qualcomm introduced the Snapdragon 8 Elite chipset. This represents a new naming scheme for the company, which wants to make its flagship products more identifiable. So it made sense that many assumed the next-gen Snapdragon 8s would use the Elite name. But it turns out that isn’t the case.
No Elite branding​
According to multiple posts on Weibo by tipster Digital Chat Station, Qualcomm could choose a different name for the Snapdragon 8s Elite. Instead of using the “Elite” branding, the upcoming chipset will simply be known as the Snapdragon 8s Gen 4. This suggests that maybe the chipset isn’t deserving of the Elite name.
Qualcomm typically launches multiple variants of its flagship chipset. For instance, Qualcomm launched the Snapdragon 888 in 2021 and followed up with a slightly upgraded variant called the Snapdragon 888+. Then, in 2023, Qualcomm introduced the Snapdragon 8 Gen 3 and followed up with the Snapdragon 8s Gen 3 in 2024, which was a slightly less powerful (and more affordable) version of the chipset.
This is why Qualcomm might not want to use the Elite name for the Snapdragon 8s, otherwise, it could dilute the brand for its main flagship series.
What we know so far​
Based on rumors, the Snapdragon 8s Elite/Gen 4 will not use Qualcomm’s new custom Oryon cores. Instead, the chipset will feature one Cortex-X4 prime core with clock speeds of up to 3.21 GHz. It is also rumored to come with three Cortex-A720 cores clocked at speeds of up to 3.01 GHz. Then, there are two cores that go up to 2.8 GHz and two extra Cortex-A520 cores clocked at up to 2.02 GHz.
The GPU is also getting a downgrade. Instead of the Adreno 830, the chipset will use the Adreno 825 GPU.
Don’t get us wrong; it is still a very powerful chipset. However, don’t expect performance like the Snapdragon 8 Elite. It will probably find its way into upper mid-range phones. This allows customers to buy smartphones and tablets that are near flagship level but without flagship prices. The new Snapdragon 8s Elite/Gen 4 will debut in early April, so we should have more information by then.
limmk
Summary: The latest leaks reveal that Qualcomm’s upcoming Snapdragon 8 Elite Gen 2 will deliver major upgrades. This includes a larger cache, faster LPDDR6 memory support, and a 30% performance boost thanks to TSMC’s advanced 3nm process. The new chip is shaping up to be Qualcomm’s most powerful yet, which is set to debut later this year.
Qualcomm will unveil its next-gen flagship chipset—presumably the Snapdragon 8 Elite Gen 2—later this year. Thanks to a post on Weibo by tipster Digital Chat Station, some juicy new Snapdragon 8 Elite Gen 2 details have leaked. Based on the information, here’s what we can expect to see in Qualcomm’s next-gen flagship chipset.
Larger cache, faster memory​
According to the post, Qualcomm’s next flagship chipset will ship with a bigger cache, faster memory support, and major GPU and CPU upgrades. Specifically, the leak points to a GPU with 16MB cache per compute unit, which could mean a total of 32MB of L2 cache. This is an upgrade from the 24MB L2 cache in its predecessor. We’re also looking at support for LPDDR6 memory. However, it is still backward-compatible with LPDDR5X for manufacturers who want to save on costs.
Additional details on the Snapdragon 8 Elite Gen 2 reveal that the new chip will use TSMC’s latest third-gen 3nm process (N3P). This is to be expected. It should also bring better efficiency and performance over the N3E process used for the Snapdragon 8 Elite. Based on early testing, it shows a 30% performance improvement.
Corroborating earlier rumors​
This isn’t the first time we’ve learned about the upcoming chipset. A past leak by @Jukanlosreve previously claimed that the Snapdragon 8 Elite Gen 2 scored 4,000 points in single-core and 13,000 points in multi-core tests. This is a huge jump from last year’s benchmarks. The GPU is getting an upgrade, too. The chipset is expected to use the Adreno 840, which is rumored to clock at 1.35GHz. This will be an upgrade over the previous Adreno 830’s 1.1 GHz.
Digital Chat Station had also previously shared an alleged AnTuTu score of 3.8 million points for the Snapdragon 8 Elite Gen 2. For comparison, the current leader, iQOO 13, sits just below 2.7 million points. If these numbers are accurate, this chip could be about 40% faster.
Qualcomm is also said to be using second-gen Oryon cores in a setup with two Prime cores and six Performance cores. This could explain the performance leaps.
Based on everything we know so far, Qualcomm’s next flagship chipset is shaping up to be a substantial upgrade. Qualcomm will announce the new chipset later this year at its Snapdragon Summit. So, check back with us for more updates.
BradenHeat
just gotten vivo x200 U,
what are the main targeted performance improvements, i would see on daily usage ?
say vs gen 3 from 14ultra xiaomi and iphone 16pm ?
As of now, limited, base on my usage seems like
- BLE
- wifi 7
- Audio
are the main selling points ,
the display is subjective, so cant say much...
RyanJ
Samsung will be be producing some sd8 elite 2 on 2nm process. Lucky Samsung production capacity not high enough will only be used in their own devices.
https://www.gsmarena.com/report_sam...te_2nd_gen_chips_on_a_2nm_node-news-67593.php
888, 888+, 8 Gen 1 were dark years for Android devices.. The recent Exynos 2500 was so troubled it never made it in time for S25. Track record for Samsung foundry has not been stellar.
Hopefully Samsung foundry can rise to the occassion, the world needs another alternative, the monopoly TSMC is having is getting costlier.
dreamcast18
my RealGT2Pro (early adopter) was 8G1...what a PoS chip..sucks battery faster than a geylang wellness professional. Thankfully the XM13U was decent.
while I would like an alternative to TSMC..i think Samsung is in big trouble given the latest ASML/Samsung scrapping the EUV facility...so let's just continue to nibble on TSMC stocks to pay for next flagship phone 😅
limmk
Qualcomm confirms late September launch for Snapdragon 8 Elite 2​
The Qualcomm Snapdragon 8 Elite 2 will arrive in September (image source: Qualcomm)
Qualcomm has revealed the dates for its next Snapdragon Summit. It will take place in late September, and smartphones powered by the SoC are expected to surface in October.
Multiple rumours hinted Qualcomm would release its next flagship SoC, the Snapdragon 8 Elite 2, earlier than usual. Qualcomm has been gradually decreasing the time it takes to launch high-end smartphone SoCs with the Snapdragon 888 onwards. Now, we have an exact date for the Snapdragon 8 Elite 2's arrival.
At its Computex 2025 keynote, Qualcomm said the next Snapdragon Summit will take place between September 23 and September 25 in Hawaii. There's a good chance we could see the next-gen Snapdragon X Elite 2 (or Snapdragon X2 Elite) laptop chips debut here as well; however, other rumours indicate it might not arrive until 2026.
Previous leaks indicate the Snapdragon 8 Elite 2 will outperform its last-gen counterpart by up to 26% in AnTuTu. It will keep its 6 + 2 CPU configuration and use an Adreno GPU that is up to 30% faster than the one that came before it. The above gains, if accurate, will come from the Arm v9 instruction set, new Nuvia CPU cores and TSMC's N3P node.
Smartphones powered by the Snapdragon 8 Elite 2 are expected to arrive in October 2025. They include the Xiaomi 16, OnePlus 15, Realme GT8 Pro and many others. Samsung might sit this generation out because Qualcomm apparently wants to make the Snapdragon 8 Elite 2 for Galaxy on Samsung Foundry's SF2 node and the Galaxy S26 series will allegedly use the Exynos 2600 on all variants.
Whether the Snapdragon 8 Elite 2 has the firepower to take on Apple's A19/A19 Pro remains to be seen. MediaTek's Dimensity 9500 is also shaping up to be a formidable competitor, but the same can't be said for Samsung's Exynos 2600. And now, there's a new player in the ring, Xiaomi's Xring O1. The first-gen SoC managed to trade blows with the Snapdragon 8 Elite, which is no easy feat.
// notebookcheck
limmk
The Qualcomm Snapdragon 8 Elite 2 chip is generating buzz with rumors of CPU clocks over 5GHz and impressive leaked benchmarks. Expected to offer significant performance gains for both CPU and GPU, it could potentially challenge Apple’s next-gen chips. An earlier launch is anticipated, meaning new flagship Android phones might arrive sooner.
The mobile tech world is buzzing with excitement over Qualcomm’s next flagship chip: the Snapdragon 8 Elite 2. Rumors are swirling, suggesting this new silicon could bring unprecedented power to upcoming smartphones. According to recent reports, the Snapdragon 8 Elite 2 is being tested at clock speeds of over 5GHz. So, get ready for a significant leap in mobile performance.
Snapdragon 8 Elite 2: Potentially breaking the 5GHz frequency barrier​
The most talked-about speculation centers on the Snapdragon 8 Elite 2 being tested with CPU frequencies exceeding 5GHz (spotted by Digital Chat Station). This is a remarkable figure for a mobile processor. It is quite possible that the final clock speed does not reach these figures. After all, Qualcomm had to find the ideal balance between raw power and efficiency. However, the very idea of a smartphone chip hitting these frequencies highlights Qualcomm’s push for peak performance. Tipster @Olrak29_ also shared listings for the Snapdragon 8 Elite 2 with a frequency of up to 5.3GHz.
Qualcomm Snapdragon 8 Elite 2 clock speeds tested
Previously leaked Geekbench 6 test results painted a very optimistic picture. Reports suggest single-core scores above 4,000 and multi-core scores exceeding 11,000. These figures indicate a substantial performance boost: a 20% to 30% increase in single-core performance and a 10% to 15% jump in multi-core performance compared to its predecessor—the already powerful Snapdragon 8 Elite.
Under the hood, the Snapdragon 8 Elite 2 could feature second-generation Oryon cores. The upgraded Oryon promises up to 25% more CPU performance compared to its first iteration. The Adreno 840 GPU is also set for a significant upgrade, with more cache (16MB instead of 12MB) and an anticipated 30% improvement in graphics performance. This translates to smoother gaming, faster content creation, and a noticeably snappier user experience.
These impressive benchmarks don’t just surpass previous Snapdragon generations. They also suggest the Snapdragon 8 Elite 2 could potentially outpace Apple’s upcoming A19 Pro chip in certain tests—particularly multi-core performance. For Android users, this fierce competition in the chip market means increasingly capable devices heading their way.
An earlier debut?​
Sources indicate the Snapdragon 8 Elite 2 might debut in late September. This is earlier than the usual timeframe. This accelerated schedule could allow Android manufacturers to announce new flagships featuring this powerful chip as early as October. Such a move would give them an advantage during the crucial year-end shopping season.
In summary, the Snapdragon 8 Elite 2 appears poised to redefine smartphone performance. With rumored record clock speeds, significant CPU and GPU enhancements, and the potential to challenge the competition, this chip is shaping up to be a true game-changer in mobile technology. The industry will be closely watching its official announcement and the first wave of devices that integrate it.
