Samsung Galaxy S23 series
Jurong640
wtf will inform the other party that its recorded?
it's for privacy purposes, pdpa. The other person also needs to "agree" for the call to be recorded.
Xiaomi phones also have call recording function, i remember they also get this message played before recording.
Sambuca78
Wah sian... Now i cannot turn off all animation in UI7 after i on off the developer mode.
Anyone face the same problem or know how to solve it? Thank
arsonn
Anybody went to service center to replace the back panel glue? How much does it costs? Nack panel popping out a lil and seems like the glue came out also
Deathzz
if no warranty might as well diy. the glue can get easily from shopee at less than 2bucks or so
FuzzyLop
Anyone know how to change the colour of the icons on the lock screen? It changed to black after updating to One UI 7
originalShrimp
Hi guys, need some help! My s23ultra have been heating up recently for no reason at all. Is there any solution for this? I have tried the cache reset and also restart but sometimes when just scrolling through instagram it goes crazy
Ev0d3vil
Anyone feels the battery drain is horrible now? I just changed battery and still very bad.
Ev0d3vil
For my S23 Ultra battery is still okay after updating to one UI 7.0. But my S24 is the one facing battery drain
Odd. my S23U battery just changed from Mister Mobile, the phone seems to get hot easily if using social media apps.. SOT definitely less than 5 hours.
originalShrimp
omg same... i havent change battery but im experiencing what u are experiencing. Yesterday i tried changing all the battery optimisation, turning on power saving, charge till 85% instead of full, and like lower the specs under the battery setting. is working much better today.
Not sure why just 2 days ago, whole phone seems like a microwave before update and after. only when i leave it to rest then it gets better so i just bought a new phone. Not a very good exp i had with samsung since i only use this phone for like close to 2 years.
twosix
My advice is to backup the device and reset the phone and reinstall.
My s23u feels normal although I can feel battery drains more than ui6.
Jurong640
I think it is expected to drain a bit more. I noticed RAM usage is slightly increased. Moreover, there is more fluid animation on One UI 7.0.
On the other hand, our batteries are ageing, more than 2 years, so will degrade slowly.
I got Care + which ended last month, I didn't go for the battery change as I feel it is really mafan. Conflicting reports from different service centres said, need to put there for many hours and some said need to do factory reset. I'm lazy to do a reset as need to restore a lor things, such as singpass, banks, crypto account, social, shopping apps.
According to AccuBattery Pro app, my battery level is at 86% / 4,296 mAh. Samsung Members app shows it's Good. Settings information shows Typical.
