Anyone here staying in 2 room BTO?
Should we move it to HomeSeekers and HomeMakers?
  • Total voters
    49
  • Poll closed .
yokine3a
if 1 or 2 pop, i put back like those crack design.
it too many i remove all and do cement sreed to be as my floor
Maybe I also do cement screed for my next house, save the trouble of getting hollow tiles 🤔
Iyarash11
my number is at 1/3 of the total units, looks like difficult to get my dream unit
Iyarash11
where to find the detailed info of the available units for SBF that was available in HDB portal during application period?
Mr.Canberra
huh 2030? now already $550k liao... :s13:
I mean for standard flats. Not Plus or Prime flats.
Mr.Canberra
I am an advocator for cement screed flooring due to budget friendliness. Got the void deck, industrial warehouse look.
But these days cement is not cheap also because HDB only permit pre-mixed cement. Unfortnately HDB no longer provide complimentary cement screed up to a certain height. The balance to zero level just need to top up cost with contractor.
As time goes by if there are mini potholes just apply leftover cement and level it with a scraper. Super easy to maintain.
Devilsire
Do vinyl also will spoil, just do waterproof cement screed, save money
No headache
cement screed also will crack from thermal stress & water evaporation, just look at all the public pathments, void decks etc :s13:
Mr.Canberra
Most people don't even live in their flat for more than 15 years. Flooring do until how nice also useless.
HDB valuator will not give higher valuation just because the marble tiles are imported from Italy.
The_King
easiest way to check hollow tiles is using marbles. Tap gently on wall tiles and note the sound.
Or tap on different areas on the floor with the hollow tiles areas
Tips shared by an ID that reno my fren house
Thanks I just do simple diy to remove air pocket
Otokiru
cement screed not cold and slippery meh?
i prefer micro clay floor and marble gum instead
