SIF GoSavers Account
ngbc
anyone has problems sending funds to your GoSaver account?
Important Notice​
Scheduled Maintenance: SIF Mobile/SIF BIZ Mobile/Online and FAST services will not be available from 10-May-2025 10:00 PM to 11-May-2025 02:00 AM due to a scheduled maintenance. We apologise for any inconvenience caused.
ngbc
~sabaisabai~
App corrupted liao. I also encountered the same after updating a new version yesterday. Today, I tried again still the same error. After installing SIF mobile on another phone, working again but have a 12h cooling period.
Read HWZ Forum Rules!
the new version of the apps? i did not update the latest version as such i can log in without issue
guess the new version causing the problem
CrashWire
today very angry
why the sif app cannot open? kenna redirected to this funny url, looks like some broken page
https://www.singfinance.com.sg/backup/violation.php
I have the same problem with iOS.
Guess I'll just reinstall the app, since I can't even login through the web using SMS OTP, only mobile token which is inaccessible. 🙄
Even reinstalling the app doesn't work! 🤮
Just tried on Android too. Their Android app is broken as well. 🙄
ngbc
You have to remove/uninstall the app, then install again as it it's new.
I'm using android.
CrashWire
I'm using android.
I found the problem. They are doing some security nonsense on the phone like what OCBC tried the last time.
The Android one only works if Developer Options is turned off. The iOS one only works on one of my spare old iPhones with nothing installed.
Anyway, with their interest dropping to match Mari, there's no incentive to use them anymore.
ngbc
You're right!
Turn on developer options and SIF mobile stop working!
ackatso
In addition to turning off developer options, you need to disable all accessibility settings that other apps may have to log into the app.
~sabaisabai~
Wah. That's quite bad if the apps not working. Imagine customer want to withdraw money
