armed robber tio brazilian jiu jitsu until rubbery arm
focus1974
epitome of stupidity.
using your body against a knife ....
your life versus losing a few dollars that can be earned back.
mastermember
If you are confident then go ahead. Else just surrender and give in to demands.
BlackWing1977
The other guy should have grabbed both his leg and do a sharpshooter on him.... then become rubber arms and legs... :crazy:
virtualape
Looks like a clinic. Should get doctor to inject an anesthestic let him sleep
Orphan
Looks like robber's left arm totally dislocated from shoulder socket leow.
Siccessful arm lock means the subduer is using the muscles from 2 arms, 2 hands, 2 legs and torso plus bodyweight against the opponent's elbow/shoulder joint muscles of a single arm. The difference in leverage is huge.
Also, damn easy to break the opponent's arm. Just need to use a bit of force to pop the elbow joint sideways. That joint is naturally strong against attempts to bends it backward, but weak when being forced out of the socket sideways.
