Singapore Treasury bills (T-bills)
papercar
I have a sum of money that just mature from the previous T-Bills, I'm thinking of whether to put in the next T-bill, or SSB.
Given the previous T-Bill was 2.3%, The next month SSB 1st year is 2.2%, I thinking to bid the next T-Bills for 2.2%. If it fails, then I will put the money into SSB.
Do you all think this is a good strategy?
reddevil0728
It might be bad if you only put 2.2% and it’s exactly 2.2%
reddevil0728
I thinking if it's exactly 2.2%, then I will put those not allocated into SSB.
instead of spreading it out for materially identical returns. u might as well be slightly more aggressive with your t-bill bid? and if turn out to be not possible then just wholesale into ssb?
vsvs24
Between 6 mths tbill and SSB, go for SSB. Rates are falling. 6 mths later, you might not even get 2.2% for SSB.
If rates move up, when you need the funds or a better opportunity comes along within the 10 yrs , you can always redeem SSB in full or partially.
ericcsn
Depends on the amount and whether you already have high yield saving account HYSA (there are to my mind about 7 out there).
If going for straight forward type, and amount is more than:
1. $80K - might want to look at ocbc 2.58% for 88 days.
2. much higher amount, need to check out premier accounts (nice welcome gifts).
sdexxxxd
Allotment
Total Amount Allotted
S$7.5 billion
Amount Allotted to Non-Competitive Applications
S$1.5 billion
Amount Allotted to MAS
S$0.0 million
Total Amount Applied
S$18.1 billion
% of Competitive Applications at Cut-off Allotted
Approximately 59%
% of Non-Competitive Applications Allotted
100%
Bid-to-Cover Ratio
2.41
Yield and Price
Cut-off Yield
2.2% p.a.
Cut-off Price
98.903
Median Yield
2.18% p.a.
Median Price
98.913
Average Yield
2.07% p.a.
Average Price
98.968
