Need help with android box
TimsTom
I got a old android box starts to have problems after i geykiang go update netflix (causing error to start and then i factory reset it.)
Now the netflix version is remote unfriendly, and the chrome or opera (i installed) both cannot play videos in them.
The_Davis
High Honorary Member
Deluxe Member
Buy a laptop or tablet instead
coyote
That's so right. I went this path and started installing Windows subsystem for Android, so that I can run Android apps in Windows. When MS terminated their support, the community took over and continue supporting WSA through the community development. The good news is that, the version of Android is continuously updated by MS and now by the community, so the version of Android will never get outdated...unlike those Android boxes which will lost support after a while.
So, I went with WSA for a while and much late, I found most of those Android apps actually have their functions supported on their website, so it's even easier to just go to their website instead of using their apps.
So, @The_Davis is right, just get a laptop and use their sites, no need to install anything. If you are adventurous, you can run WSA on windows and run their Android app also. Intel or AMD x86 architecture is so much more powerful than the Android CPU, so those apps runs faster in Windows WSA than in android boxes.
The_Davis
Deluxe Member
And use browser like brave that got built in ad blocker
articland05
buy a Nvidia Shield ba
better then those crappy China android box
nvidia still giving updates to my 2019 shield model
Go Fly Kite
Old box maybe need flash player? If netflix app is system app, Why didnt try uninstall all updates option first b4 resetting. Tv box have own app store? If have try downloading there.
TimsTom
Ok, so what help do you need?
Ow to watch videos in browsers again n have netflix more remote friendly
Ya, i thought reset would just bring it back to when i first started, didnt know would become worse.
Contact seller / supplier?
I dont think they would have any after sales services
Go Fly Kite
Sorry if i cant remember correctly, If the box got its own apps store, firstly after ur reset, go to the tv box app store to dl/update the app u need. Not play store.
If dun have tv box own app store, i rem got some china tv app which operates like an app store de. Paisei cant remember name liao..
batuchka
get online search for older versions of netflix apk loh experiment a bit? install n uninstall until stability reached (y) if you lucky maybe can find post on your specific box SOC and best netflix apk version else trial n error...
PiKa
Buy a amd chip windows based mini PC can liao.. can climb mountain, swim in the stream, no issue
