TanKianW
- Apr 21, 2005
Quite happy with the result as the presence & luminance data is immediate in realtime as it is wired. It even allows me to take care of one of my partner pain points which is light of dumb ceiling fan which can switch on by itself during daytime. As the illuminance sensor is sensitive and immediate, calculating the difference of illuminance level using pyscript & sensor data automates the irritating light-on away by sending RF command to off the light with pyscript. Big upgrade to the Tuya PIR/presence sensor mentioned which is useful in other use cases (toilet).
The Tuya PIR+presence sensor worked really well for my use case. I have replaced most of my washrooms and rooms with it. With a well-planned ZB setup, it is almost instant. Furthermore, there are no wires, so it can be easily deployed anywhere in the house.
