Our water heater is now causing our circuit breaker to trip, can it be fixed?
hachi
I dont buy Joven. Champs or even Europace is good. Use over 12+ years no issue until I have to replace due to reno.
Most intro joven.. My plumber course trainer and my contractor... I bought 35L storage heater.
Can Or Not
Our Joven heater is now causing the circuit breaker to trip every time we try to turn it on. Purchased in March 2023, i think its just past the 2 year warranty period.
Is this something that can be fixed if we call a technician? Or do we need to buy a brand new one? If we need to buy, can anyone recommend a reliable brand? A water heater should not be breaking 2 years after we purchased it...
Brand new one… I don’t think it’s economical to repair
Jian19
Today weather hot nvm one , tml than call joven service center see how :o
Dopod007
Electrocution from a water heater can occur if the heater's internal components leak electricity into the water, or if a faulty installation or wiring creates a path for electricity to flow through a person. This is particularly dangerous in bathrooms or when using a water heater in wet conditions.
How Electrocution Can Happen:
Internal Faults:
A faulty heating element or wiring within the water heater tank can cause electricity to leak into the water, creating a shock hazard.
Poor Installation:
Improper wiring, such as using an inadequate power source for the heater's wattage, or failing to properly ground the appliance, can lead to electrocution.
Faulty Wiring or Components:
Damaged or corroded wires, or a faulty grounding connection, can expose electrical components to water and create a shock hazard.
Water Leaks:
If a water leak occurs within the heater's casing, it can expose electrical components to water, increasing the risk of electrocution.
Tripping Plugs:
Overloading a three-pin plug with a water heater can cause the cables to fuse together, potentially energizing the water heater casing and creating a shock hazard.
Lack of Safety Devices:
If a water heater's circuit isn't protected by an RCCB (Residual Current Circuit Breaker), it won't automatically cut off power in case of a fault, increasing the risk of electrocution.
Safety Precautions:
Professional Installation: Always have a water heater installed by a qualified electrician and plumber.
Proper Wiring: Ensure the water heater is wired correctly and grounded properly.
Regular Maintenance: Have your water heater inspected and maintained by a qualified technician to catch any potential problems early.
Check for tingling sensations: If you feel any tingling sensation when using the water heater, stop using it immediately and have it checked by a professional.
Wear slippers: Wear slippers when showering to reduce the risk of electrocution.
Cut off power: If someone is electrocuted, immediately cut off the power supply at the main electrical panel.
Additional Information:
A water heater is more likely to cause an electrocution if someone is in direct contact with the water, or if they are wet.
The risk of electrocution is higher when the water heater is on and in use.
Even if the water heater is off, it can still be dangerous if it has a faulty connection or wiring.
alex22
Internal Faults:
Poor Installation:
Water Leaks:
Tripping Plugs:
Safety Precautions:
Propose mod to give point recognition to peepur who post WOT FROM CHATGPT
djkopikat
i last time sell heater one...alot of time, its the electrician tat used a thinner or underrated wire to join the heater to the power pt, this caused arcing whereby the high current jump over the jointing part .. either u engage another electrician to solve the problem, or u can call joven also, but of cos if joven find out it's the installation problem, its only fair they charge u..just ask the cost involved b4 committing them to come look at ur problem.. cos based on sales record of joven heaters, they seldom spoilt...
nachtsid.er
Yes, you can change the heating element inside
archie7
better get electrician to do it
water + electricity not funny when comes to life and death
be safe
Questin
chiu got voltage meter?
No.
Joven wants $70+ diagnostic fee because its not under warranty anymore. Not sure what the full charge is like but i suspect will be quite expensive. Where to find a technician to repair without getting chopped?
djkopikat
No.
ask around ur friend tat recently renovated house...mostly they wont anyhow if its recommended
pt to know: the joven diagnostic fee is fair, becos alot of time its they r cleaning other ppl backside, due to improper installation... so u can ask further the cost of rewiring or rejoint the affected part, then u ask the outside electrician how much. u do a price comparison b4 u engage whoever to come...
randyap
heater i feel is the simpler the better. The more functions you have the more likely things can go wrong.
TopGun
How much did you pay for the heater?
Personally, I would rather replace the entire thing.
lobstercrab
When this happened to me, my electrician just asked me to replace...new one oso not too expensive, don't think you shld repair...
randyap
be happy that the safety feature kicks in and trip your circuit. if i were you i would just pay to buy a new one.
keewee0415
Reliable brand can consider one Japanese brand trusted by PG and boomers call KDK.
