I bought this powerful Air Duster
testerjp
The top ranked Wolfbox MF
The top ranked Wolfbox MF100 now on sale on Lazada @$89. I just ordered one
I bought from Taobao $70. It's under another brand.
飓风侠X17暴力风扇高速手持涡轮风枪吹雪除雪吹风机手持最新款​
TopGun
Bring the item to corridor and whack. I used it on my PC, dyson fan, car in conjunction with a vacuum. Etc. Useful.
jtjt00
Last time Hardware Clinic all raving about this:
I'm still using this.
testerjp
I just used it to clear my PC.
But those sticking onto the plastic surface around the fan can't be removed, i think there's grease to it or something.
Otherwise, the mainboard is damn clean now. :o
paul02
Try try for $57, should be more powerful than my Nitecore blower.
Phen8210
licorne_strong_portable_air_du_1743677489_a2babbe2_progressive
WolfBox is noticeably louder than NiteCore. 87 dB vs 77 dB is actually a big difference due to the logarithmic nature of human hearing, and the recommended is stay below 85dB.
The ear can be exposed to short periods of sound in excess of 120 dB without permanent harm — albeit with discomfort and possibly pain — but long term exposure to sound levels over 85 dB(A) can cause permanent hearing loss.
https://en.wikipedia.org/wiki/Noise-induced_hearing_loss
Some time ago, I actually tried both the Licorne and WolfBox, and true enough the WolfBox was actually causing my ear drums to hurt when used for extended periods, although people with already minor hearing loss would probably not notice it.
The Licorne is much more manageable noise-wise and still delivers strong performance (168 mph, 66 CFM, and 122g pressure), it was enough to blow a 500ml bottle off the table. For me, It's easily the real rank 1 as its safer for daily use.
pokipoki08
have both the mini duster and makita cordless blower
mini duster battery don't last too long 10mins?, small and handy for small compartment eg car dashboard, slim vents
makita blower need 2 batteries to blow dry car after wash
thought of getting a real petrol leaf blower to vacuum dry leaves for compost but found out its really damn LOUD, will rock whole neighbourhood lol
黑橙X3-M(显示屏) 8000毫安 +吸尘嘴19.8*4.5*17CM RMB 145
comes with 2 nozzles for blow or vacuum
from 1688.com, can use taobao password to login, need freight forwarder
expensive items best to buy from 1688, many taobao sellers markup and dropship from there
pokipoki08
can use to blow dry car bo?
mini blower battery cannot last that long
but makita blower can
bought 2 battery but 1 will do the job
https://s.lazada.com.my/s.JczRL
when attaching battery the joint clip may be loose coz its new, may drop when using blower
blower save time and energy for the polishing car later coz drying car body using microfiber towel is really tiring
Phen8210
The licorne portable electric duster max speed will last about 20 minute at max speed.
and yes for a lot of blower > 80dB the noise is a real concern.. only a person who never take care of their ears will find it ok lol.
Godeau
i had this, very noisy and need blow outside of house if not the dust just gets recirculated in the area. Intake suction below have to clean the sponge if not will choke..
Use a few times only, too noisy imo, vacuum cleaner level+ noise
die
using $60 wet/dry vaccum with blower ....
super noisy but get the job done
normally i wear my headphone on anc while using it
but blowing pc have to bring outside
or inside the toilet :ROFLMAO:
