tian_yibang
- Oct 24, 2019
Diff ss outlets all hab diff offer ie. some 3 for $1 , 5 for $2 , 6 for $2
Which kdk store is it btw, forgot to ask the other time$10 voucher + $20 coins
yes you can, but one time can only scan dunno how many columns which doesn't exceed $300. so might need to scan two times.Gain City accepts the climate vouchers for online purchase, maybe can see2 look2 there.
https://www.gaincity.com/catalog/category/view/s/fans/id/3201/
So we can pay fully using the vouchers if less than $400?![]()
wah so good leh..the delivery man will scan the climate vouchers upon delivery.Gain City accepts the climate vouchers for online purchase, maybe can see2 look2 there.
To get it right, have to first airfry at lower temperature to get the meat cooked, then higher temperature to get the crisp. I lazy to stand by the airfryer so hardly bothered.I bought drumstick and tried to airfry... its either skin crisp but inside a bit red, or skin dry if I wanna ensure inside cook.
Now I steam it, with hardly veg like cabbage or Chinese yam below. Felt healthier cos it seems not so salty.
I stopped buying these coz of the salt content. I read about removing excess salt from processed meats, one way is to boil and remove the liquid. Figuring that would remove the flavor, I've switched to buying unseasoned ones and do my own simple flavoring.
Definitely taste different. But I'm alright with that (buy mine from SS), not bland but I can't really cook so make do with whatever I can come up with. Normally just sprinkle black pepper, tumeric, and chilli powder, then rub rub. Lazy.i recently bought raw unseasoned drumsticks from thailand. my mum braised it but somehow the meat taste bland though juicy. Those frozen one really doesn't taste the same as fresh chicken.
can make small cuts on the meat to ensure inside is cooked properly. temp is set at 200 degrees and air fry for 15 to 20 mins.I bought drumstick and tried to airfry... its either skin crisp but inside a bit red, or skin dry if I wanna ensure inside cook.
as good as ntuc's brandHas anyone tried the SS Heritage Farm Potato Chips? Good?
Too bad they don't have no-salt ones. In fact, can't seem to find any salt-free potato chips from SS...
Only emptyuc has one from their home brand, but have to walk quite a distance to buy, and app seems to show "low stock" which can mean "no stock" as well.
Kettle have unsalted potato chipsHas anyone tried the SS Heritage Farm Potato Chips? Good?
why not u diy?
but frying it still defeats the purpose anw
salted or otherwise![]()
DIY... I might as well just boil/cook potatoes and eat. Too lazy lah.as good as ntuc's brand
have tried it all
will buy it again if there's an urge to
why not u diy?
Expensive snacks...Kettle have unsalted potato chips
But their chips quite expensive , sometimes have offer 2 for $9
Quit big pack I think 150gDIY... I might as well just boil/cook potatoes and eat. Too lazy lah.![]()
Expensive snacks...![]()
I did diy using frozen pratha. I figure out since what I want is some crispy snack, I cut frozen pratha into smaller slice and airfry it.
Also tried wanton wrapper and popiah wrapper. Cut into smaller pieces, throw inside a plastic bag and pour some oil follow by herb seasoning.
