Nah bruh, sensor detect as full depends entirely on how your pucks land inside the container. There are times when just after 2 shots i.e. 2 pucks, the container full, because the 1st puck landed 45degs at the side and the 2nd puck dropped on top of the 1st and didn’t slide/roll down.
There will also be some dripping inside when you do a manual rinse and/or when you switch off the machine it does the short rinse before it switches off. That water also contributes to mold.
My clean-up after making a coffee, to me is no different from using a portafilter type machine already … maybe even more. Which is why I’m toying with the idea to switch to one![]()
Yes, but generally about every 2 days the pucks indicator will light up
