Realistic People Club
wongminmin
Moi can't even piak Bro wongminmin!!! :(
wlwl 12/6/2025 new toto betting system!!! Bro Crimson! :(
For this type, prizes differ based on how many numbers the player selects in one bet. For every dollar bet, players can win $50 for two matched numbers, $500 for three numbers and $7,000 for four numbers.
In the second game type, players can choose one number from one to 49. They will win $30 for every dollar bet if this number matches the additional number for that Toto draw.
Its just like roulette but with lousier odds Bro wongminmin!!! :(
RandomPancake
should wait longer for the singles prices to drop?? or will chiongz upz?? moi worried they might chiongz upz... @RandomPancake :s22::frown:
If worry just buy now:(
Your yuffie is the fca series one? Going for foil version? If going for foil version can stalk singapore mtg auctions Facebook group and try bid when you see it.
Fca cards foil version is only in collector booster box, price going down because people peg to US card kingdom price, but then stock wise not alot of people selling :(
If non foil version then moi not sure also :(
Travis_Touchdown
ijjit look at the lower left corner of the card?? think the yuffie one ish fic?? :s22::frown:
huatz the difference between foil and non-foil?? tot non-foil ish normally cheaper?? moi juz wan all the cheapest option de... :s12::frown:
RandomPancake
Ya look at lower left corner
Depend lor, certain card non foil or foil same money or sometime non foil even more expensive, but for cases where non foil supply way more than foil one, the foil version price will shoot through the roof.
You collecting non foil one, for this set honestly don’t know how it will turn out.
Fic I think will drop price but may or may not be able to find the card, for reference you check other sets commander deck cards, some cheap but won’t have stock anywhere one.
Fca one price may or may not drop, this one not sure.
Yuffie got both fic and fca one, both ninja
Fca is reskin version of yuriko, the tiger’s shadow
Travis_Touchdown
huatz ish the difference between fic and fca?? :s22::frown:
notch say collecting non-foil one... whichever cheaper ish will take whichever... if same price then take foil since foil looks naiser... :s12::frown:
the yuffie original one better coz gotch different abilities... reskin of yuriko meaningless to moi... since moi oredi gotch yuriko riaoz... :frown:
RandomPancake
Fic is card from the commander deck
Fca cards are all reskin of existing cards
The fic yuffie is mono red ninja, can fit into your commander deck? Curious what’s your color for your ninja deck
