Where to Go For Allergy Blood Test?
sonic
My friend hold a work permit and is regularly having some allergy due to some food.
Where can he go for a allergy blood test in Singapore?
Any good clinic to recco?
Thanks.
David Lai
skin dept of any major hospital should do the trick…
or nsc, like what a bro/sis had suggested…
bombshell
Food allergy how to test? Let u jiak all the fish, prawn, abalone ho liao and monitor see which one cause u to lao sai?
NintendoSwitch
Thanks.
Hospital specialist clinic. It is on the right after taking the escalator down. They have this rectangular block full of pricks that they poke your arm with. You're allergic to which ever swells. Spend about half the day there doing it. You will need a referral to setup an appointment since it is an SOC.
The device looks something like this.
multi-pronged-test-device-skin-prick-allergy-test-multi-pronged-test-device-skin-prick-allergy-test-267605002.jpg
Your arm will be drawn like this.
The ones that swell up are what you're allergic to.
batuchka
as a yang lad in the mths leading to enlistment date i suddenly realised i was allergic to oppression and enslavement :sneaky:
