how to stop HWZ screen from jumping as page top banner ad change size?
iantao99
how to stop HWZ screen from jumping as page top banner ad change?
read a line half way, it disappear.
i find it quite annoying leh.
does anybody else face this problem?
this day and age, don't think software design will be so weak ba.
is it my laptop config got problem?
teoth76
I use DuckDuckGo browser, auto blocks. I think there are other similar browsers
KakiMeow
install adblocker ...
... it ish extension for Google chrome
or use Brave browser lo
PiKa
moi use hermit wrapper on mobile. no see all these
win_man
i use ADP, UBlock Origin and Adguard
Mobile i use ADP
iantao99
what do you mean, can screenshot show?
can't show with screen shot as it is a momentary thing.
As the top of page banner adv change from 1 adv to next adv, when the initial adv is removed, the forum page moves upwards to fill the gap left by the removed adv.
When the new adv is added back to that space, it pushes the forum page down again.
It is a 1 second thing fast but enough to annoy when u r reading and the line disappears on u.
NintendoSwitch
I dun have dat issue on Windows since every single one of my browsers either already comes with adblocking built-in or has one of those adblocking extensions. The mobile site is quite terrible on Android browsers without adblocking. There will be a pop up bar that appears sometimes and messes up the formatting. No issue on those Android browsers that either have built-in adblocking or allows adblocking extensions. Why not just install any adblocking extension to your computer since they are free for personal use? Unless it is your company's computer then better not.
