mooseolly
- Mar 21, 2009
Air drop is like let’s say I want to send an attachment (screenshot, pdf, anything) to my imac/ipad/iphone I just press air drop and it can be sent over immediately.Most of those can be done on Google. Some of them I dun use at all like Air Drop so I have no clue. U can move them one service at a time to Google and test water to see if it ish really a catastrophic disaster or if it's acceptable. The onlie item in dat list dat seems to be no go from wat I nor ish Apple Watch.
Apple password is also very important to me because once I store them, any apple devices just do biometric authentication you can login your website or apps. It helps me to generate and store a random long string of passwords which I do not have to remember.
Apple maintained the tight integration between hardware and software and so far others can’t replicate this experience yet.
Even if you lose your ipad or iphone, as long as you can login your icloud everything can be reinstated including the application data, your apps icon position, wallpaper etc as if you are still using your lost phone with the wizard.
Things like let’s say I left my air pod at the cafe, my iphone will prompt me and ask me to take.
And like if My iPhone is connected to wifi, when I open my ipad it will prompt on my iphone share wifi password automatically.
