Man suffers gunshot wound while cycling in restricted forested area near SAF live-firing activity
106gunner
What weapon? SAW or MG? Unlikely SAR21.
The General Purpose Machine Gun (GPMG), specifically the FN MAG, has an effective range of 800 to 1,800 meters when mounted on a tripod. When mounted on a bipod, the effective range is typically shorter, around 800 meters. The GPMG is a versatile weapon used in both light role and sustained fire (SF) roles.
Here's a more detailed breakdown:
  • Effective Range: The GPMG can be effective at long ranges, with effective ranges varying based on the mount. On a tripod, it can reach up to 1800 meters, while on a bipod, it's typically effective up to 800 meters.
  • Sustained Fire (SF) Role: In the SF role, with a two-man crew, the GPMG can deliver a high volume of fire (750 rounds per minute) at extended ranges.
  • Rate of Fire: The GPMG has a cyclic rate of fire of around 750 rounds per minute.
  • Caliber: The GPMG uses 7.62x51mm NATO ammunition.
gilcrest
“The public is not allowed to access that particular area, which has signages warning against unauthorised entry into a live-firing area," the police said.
Signage serve no purpose as durian season is near. Expect more trespasser in other restricted areas.
samferguson
Haha lol I still remember during my NS Bn Ex, out of nowhere a civilian ah pek cycle slow and steady right in front of our coy defense position 😅 everyone tio chuat.
gilcrest
My friend lagi worst, went in go pick durian with other friends. Area quiet and that was the era when they changed to pixelated uniform. Suddenly a company stood up and charge forward scaring them running amok; end result twisted his ankle. point of the story was the pixelated uniform worked
gilcrest
Exactly and it's not exactly like just outside the range...He was quite a distance away..
Circled is the range..the dotted dash lines are the known illegal trails...The rest are basically vegetation...
Likely shot the sky, 2km range, bullet got no eyes
