How to reduce car sway and bounce when crossing road hump?
hongge
Perhaps anti-roll/sway bars or spring stiffeners could help reduce it slightly? After installing the anti-roll bars, my car feels more stable when crossing humps.
enimen
Last time my old car go over each hump like inside bouncy castle like that
hachi
At what speed?
hachi
Second that, KYB makes a different from stock shocks. 2 different cars changed to KYB better handling and less noise
Yes kyb G series should be cheap and good. Very lasting too..
keenklee
I driving a 8 year old Kia Cerato.
Everytime go over hump I feel like my car sway and bounce gaolat gaolat.
Sometime the feeling is like on a boat rocking and it keep bumping into the berth that kinda feeling. Sibeh uncomfortable.
Is there any mechanism to look for when changing new car to avoid such feel? What Air suspension and what not?
IMHO.
1. Tyre pressure between left and right are equal.
2. Typre pressure is correct for cold tyre pressure.
3. Tyre speed rating and size is per tyre placard.
Usually 8 years, time to change shocks but also have to depend on mileage.
Like my tyres, off by 5 kPA is noticeable difference.
hachi
Why people here cross hump will be unstable? They make sure all 4 wheels on air? All don't slow down and cross it? Then shocks not lasting if driven like this.
EJB
Sway install strut bar.
Bounce you can install harder springs. The car wil become very stiff though.
hachi
You guys cross hump and corner at the same time? Why need strut bar? Sway bar? Anti roll bar? Just replace shocks..
kage
Before hump stop the car, look around see got bui bui dinobus, call them sit inside car, then cross the hump, once cross call them all get lost .... :o
Confirm reduce bounce by alot 🤗
fartking
Change your anti-roll bar to bigger dimension, install back wheel and front wheel struts for stabilizing.
starry_starry_night
Is there any mechanism to look for when changing new car to avoid such feel? What Air suspension mrt and what not?
Take mrt instead
kage
On a side note, normally a car manufacturers aredy calculate the best wheel size for the car ...
Many itchy backside including myself go change bigger rim, tyre width, end up car more hard bump .... DLLM :o
viethai
Check, replace suspension or lift yr butt up when approaching road hump
DragonFire
Sway bars are actually quite common stock these days. If TS is experiencing serious wobble, my feel is that the sway linkage is broke.
