HELP! Recommend a neck support pillow please.
Firestorm1978
I am a back sleeper and tend to slide down while sleeping (even when I place pillows under my knees to alleviate my legs). Always end up with stiff neck or neck pain after waking up. I have bought many so-called neck support pillows (mid range pricing, not those few hundred atas type) but to no avail.
Anyone can recommend me a tried-and-tested neck support pillow or share personal experience (similar to mine)? Also, any shops here that can customise pillow after analysing my sleep posture?
Thank you.
jq1986
Check out the tempur original pillow that is designed specifically for neck support. Woke up 2 times (across a couple of years) with a frozen neck/shoulder that lasted for weeks and decided I didn't want to live with such 'random' pain. Quite pricey, but haven had the same issue since.
mosmos
High Honorary Member
Go nitori get mochi pillow, chiu need a flat one not support till neck stiff + pain
Moi hab same problem rast time, tot support pillow better, end up ish flat one solve tis problem almost next day
Firestorm1978
I was tempted with tempur but they have so many types, including neck support. Not sure whether to get 'original' or the specific one for neck support. Worried about buying such an expensive pillow and ends up still neck pain.
How much did you pay for the pillow? The neck pain has been tormenting me for years.
Firestorm1978
Thank you. Never heard of Nitori before. When I google it, it indicates that the store is permanently closed?!
iammole
seahorse coral foam pillow @ $9.90.
I using one , before sun faint smell, after suning no smell.
rrr2015
Thank you.
weak/hump upper back may cause neck strain as well
DulanMax
Ethan_
Think unless one secure self to the bed, if not, during sleep one will tend move around one bah. Have to constantly adjust the pillow if want it to sit firmly often.
Firestorm1978
LOL, I worry I may have to tie myself up in order not to slide down during sleep.
tmkedmw
Thank you. Saw a number of nice reviews about it. However, did you use it personally? If yes, did it resolve the stiff/painful neck issue for you (if you have this symptom)?
I don't have stiff neck issue.
More for comfort and material is cooler
Nakedtoes
Go taobao and find.. They have adjustable height type... Every one shoulder / neck height and needs are different.
