Anyone stopped dumping toilet paper into the toilet bowl??
testerjp
Won't get clogged so easily, under the bowl there's a big opening, if its clogged it is likely happening at your bowl.
If the toilet bowl can clog with tissue, then as well don't sh/t on it since the sh/t is harder, more solid and more likely to clog than your normal tissues.
Anghtj
Toilet paper with **** can throw where? I know how to clear choke though. I use a mop to pump the toilet bowl. Always work.
eyz
buy cheaper toilet paper.
those when contact with water after a while, will tear up.
kreja
Only in overseas la. I think for countries like jpn or tw, their system cannot handle big load of toilet paper
deepblue_82
if u dont throw alot at once no reason it will clog...
but if u throw alot at once then will clog
coyote
Seems that this is a viable solution
Need to minimize the number of wipes used
Someone suggested installing those water jet washer to reduce toilet paper usage. You can try. Reducing water usage versus reducing toilet paper usage, I don't know which is greener?
accucore12
u throw whole roll isit?
Or your sai too big, need take sai cutter cut first before flush?
i use many many piece per pangsai also no problem. never had a problem.
