That’s the router which is the same model that they will be giving me too.They gave me HB710.
how abt the fibre modem? Is it nokia or huawei?
Actually this Nokia XS-240X-A XGS-PON ONR is usually use as ONT and there are better Nokia ONT that can provide full 10Gbps speed or near 9000+ Mbps instead of the present up to 8200 Mbps only.Most of the Starhub users should get Nokia XS-240X-A XGS-PON ONT for 3Gbps/5Gbps/10Gbps plans.
MR users are reported to get Nokia XS-250X-A, XS-240X-A or XS-140X-A XGS-PON ONT.
Starhub/MR no longer use Huawei brand for XGS-PON ONT, only Nokia brand.
SingTel is using ZTE F8648P or Nokia XS-240X-A XGS-PON ONR. Same for Whizcomms. Take note Nokia XS-240X-A can be configured as ONT or ONR.
VQ is using FibreHome or Huawei brand ONT. VQ also has an offer of Huawei brand SFP+ ONU for power users at S$99 extra.
SIMBA is using Huawei brand ONT.
All in all the brands of the ONT/ONR do not really matter to the end users, rather it matters whether it is an ONT or ONR. Power users will avoid ONR.
I read online that Nokia has a new ONT that is fast and can reach such speed.Who tell you this info about 9000+ Mbps?
All the current consumer 10Gbps plans offered in Singapore are based on XGS-PON technology and this will limit the speed to be about 8.3Gbps.
https://www.fibermall.com/blog/10g-pon.htm#:~:text=On the other hand, XGS,upstream applications like video conferencing.
You happen to know if there is a default router pwd or did the installer tell or or ask u to set the pwd?They gave me HB710.
Anyone knows for the hb710 when starhub set it up, what is the default admin pwd? SH did installation for me but I forgot to ask abt the admin pwd. I cannot login and calling 1633 couldn't help either
Take note you may have to reset the router if the installer changed the password and yet forgot to tell you, or you changed the password during the installation process but later forget.
TP-Link Singapore FAQ
https://www.tp-link.com/sg/support/faq/4370/
How do I find the device login password for TP-Link ISP-customized Modem Router?
TP-Link ISP-customized (operator-customized) modems/routers are pre-configured with settings specific to your Internet Service Provider’s (ISP) network. There is no universal default password, as credentials are typically set or managed by your ISP.
Use these methods to locate or reset your password:
1. Check the ISP documentation.
Refer to the manual, setup guide, or support website provided by your ISP. Credentials are often listed there.
2. Inspect the device label.
Check the bottom label of the device for any printed login password.
3. Try the following common default passwords as per your region & provider:
Country ISP/Model Common Default Passwords Australia Alladmin ACTact@123 AGLsupport180 Amaysimadmin1/admin1 Australia Post Broadbandapbroadband$ Matemate12345 admin1 otn230 New Zealandpassword1 ax3000 Singapore HB serialsGUI password printed on the bottom StarHub (Except HB710)StarHub@1234
Starhub@1234
starhub@1234
StarHub@123
wireless password printed on the bottom Otheradmin1234!
tplink1234
tplink123
admin1234
Qawsed1234
Admin@1234
4. Contact your ISP.
Your ISP’s customer support can confirm or reset the login credentials, as they provision the device.
5. Reset to factory defaults to create a new password.
Warning: Resetting erases all settings and may cause the device to lose internet connectivity.
I got it too, this is only for new sign up right? $29.9 is good deali received an sms from singtel ytd saying there is a 3gbps plan for only $29.90/mth and is with their wifi 7 router. did anyone receive this too? sign up is by 30 sep. might be a good deal at this pricing sia
this the link included in the sms: www.singtel.com/personal/products-services/broadband/eform/ga-edm/3gbps-plans
Thanks for sharing. Seems like a good deal. Dont know if anyone can sign up or targeted?i received an sms from singtel ytd saying there is a 3gbps plan for only $29.90/mth and is with their wifi 7 router. did anyone receive this too? sign up is by 30 sep. might be a good deal at this pricing sia
Nice one. Thanks for the update.
This is a very good offer for SingTel:
S$29.90 per month for 3Gbps plus one HB611-SGST unit.
The other SingTel recontract offer is S$39.90 per month for 3Gbps plus two HB611-SGST units.
They will have to upgrade their backend devices OLT again? Singapore willing to spend money to upgrade again?The real world performance of the so-called 10G rated XGS-PON technology is only about 8.3Gbps, so there is no such thing as a better Nokia XGS-PON ONT.
Other countries and regions use the new 25G PON or 50G PON technology to deliver true 10Gbps plan (≥ 9000 Mbps) and 25Gbps/50Gbps plans. But 25Gbps/50Gbps plans are niche plans and expensive now.
I expect Singapore ISPs to offer such plans (true 10Gbps and 25Gbps plans or even 50Gbps plans) based on 50G PON technology before 2030.
Yes you are right as AI said Upgrading a Nokia OLT from XGS-PON to 25G PON is designed to be a relatively easy and non-disruptive process that does not require replacing the optical cables.Why not when the technology is mature at that time? Take note I mention 2030. The technology should have already been quite mature at that time since there are already 25G PON and 50G PON trial run now.
This offer is below the table offer? need to call and ask for it then will be offer?Existing Starhub users may want to check with Starhub to get a much better 10Gbps recontract offer at S$30.49 per month with free HB710, that beats all the offers out there from any ISPs.
