MIVEC525
- Feb 8, 2003
Scare white elephant...not use to magic os, better than samsung UI?Just buy loh $400+ nia ,jip jip....
I need to update you that the Honor service center has move to Plaza Singapura.Have both flagship and mid range phones (magic6 pro and honor 90), quite shocking the latter not only lack of voLTE support but is not durable too ,screen went blank, ended up paying $90 for the repairing of the motherboard three months after the warranty expired
Flagship is good.... Still using it to connect TV for mirroring
Please check does this X9D supports voLTE
Going to the service center is not convenient, have to take a particular feeder bus from aljunied MRT, just that service number
If not because of using foldable, I would have considered this X9D too as it seems good
Pros
IP68/IP69K dust tight and water resistant (high pressure water jets; immersible up to 6m)
Drop resistant up to 2.5m
120Hz, 3840Hz PWM, HDR, 800 nits (typ), 1800 nits (HBM), 6000 nits (peak)
90.9% screen-to-body ratio (slim bezels)
Cons
108 MP, f/1.8, (wide), PDAF, OIS
5 MP, f/2.2, (ultrawide)
USB Type-C 2.0 (slow transfer of files)
66W wired (not fast enough for a 8300mAh)
Took 44mins to fully charge a 5600mAh, so I reckon it takes 66mins to fully charge X9D
For Android, tiagong Samsung UI is the bestScare white elephant...not use to magic os, better than samsung UI?
Got free Tablet, 2 yrs warranty. front and back screen warranty, water ressistant waranty...get the 256GB $449...
Is it a good buy??? never use Honor before. Spare phone.
This camera better or the A55 5G?For Android, tiagong Samsung UI is the best
At least you do not need to delve deep into the system just to access "app info" ,can do it right at the home screen
Oh shiatU all Google Honor service centre
Many 1 star reviews
Really no good?Oh shiat
Just referring to their service centre. If you're buying tis hp just for d free tab. Hope it's worth it.Really no good?
I thought Magic OS can do it now? I remember I had seen it on the demo phone.For Android, tiagong Samsung UI is the best
https://m.gsmarena.com/compare.php3?idPhone1=14176&idPhone2=12824#diff-This camera better or the A55 5G?
Wow I'm surprised you bought x9bi have honor x9b the ui is good. resembles ios so ez to use
i use it to whack walnuts openWow I'm surprised you bought x9b
Not going ahead with foldable?
I ask it's voLTE supported.Have both flagship and mid range phones (magic6 pro and honor 90), quite shocking the latter not only lack of voLTE support but is not durable too ,screen went blank, ended up paying $90 for the repairing of the motherboard three months after the warranty expired
Pros
Cons
