Stay landedbut if stay below others suay kenna corpse water how?
You can't compare old hdb with new hdb. The new ones have better design and technologyof course new is ok. but nobody experience like 10-20 years
but last time hdb only single layer at the roof. nowadays got double layer. still got air gaps in between.
Last time hdb already have double layer. Cement block tiles lay on top of a brick lattice basebut last time hdb only single layer at the roof. nowadays got double layer. still got air gaps in between.
Stay more quality hdb. Buy those low quality one jialatBut stay below others might kenna corpse water? So which one is better?
However good quality also cannot stand lack of maintenance, plants removal from rooftop, waterproofing renewal, pipe sealing fail cos corrosionbut last time.. they build with TLC and construction materials are all good quality.
hehe..
My house top floor. Ceiling not hot (maybe because have solar panel)
Ceiling no leak , very windy , wait for lift not an issue , unblocked view .
issues I occasionally faced are lizards and teenagers at staircase smoking or do hanky panky stuff.
Given a choice again I will choose top floor, the higher ceiling height is good
Yes, stay top floor worst. Hot, water leak.
Best is stay ground floor. Not even middle
If chio bu then is high quality?corpse water got because good or low quality meh?
Impossible to leak unless the contractor of the hdb is laoya already and reno contractor laoya togethercorpse water got because good or low quality meh?
Bituminous Waterproofing and the additional raised tile mai mix upgot some with point ceiling. but some flat one they use those black tar to coat the roof top.
hehe..
