So thick leh the concrete. If got lay tiles leh?but corpse water could be due to stomach acid.
The rooftop will leak when water proofing failBut stay below others might kenna corpse water? So which one is better?
Please lah. My mom's staying up top floor for over 20 years. Simi water leak? TC carries out roof waterproofing every 10 years.But stay below others might kenna corpse water? So which one is better?
Yes, water can seep through a cement floor because concrete is porous, not waterproof. The main causes are hydrostatic pressure from water buildup against the foundation, cracks in the concrete, and poor drainage around the building. Other factors include plumbing leaks or a high water table.So thick leh the concrete. If got lay tiles leh?
Mean the concrete floor already 偷工减料。then the reno guy lay tiles also cut cement etc.
You read about the blood water news. They say the water proofing of the floor or ceiling goneYes, water can seep through a cement floor because concrete is porous, not waterproof. The main causes are hydrostatic pressure from water buildup against the foundation, cracks in the concrete, and poor drainage around the building. Other factors include plumbing leaks or a high water table.
Yes, water can seep through cement tile, especially at the grout lines, which are often more porous and can deteriorate over time. Factors like cracked tiles, improper sealing, and a poor subfloor installation can all allow water to penetrate, leading to moisture problems in walls and floors.
Believe in science
My hdb flat is on the top floor. Have to monitor rooftop water tank for leakage to my unit from the kitchen and bedroom ceiling.
Over time will have ceiling spalding. Need to pay TC to replaster.
I'm disappointed that my top floor unit don't have higher ceiling
only the toilets don't have waste water pipe.
Then might leak due to corpse, could be worker died unnoticed.depending on the hdb design
i saw some the ceiling is not directly the floor of the roof....there is another structure so heat may not be an issue
like that mid floor best???
Mid airBut stay below others might kenna corpse water? So which one is better?
My parents stay top floor 12th storey flat.
After 20th year mark starts to encounter leaking issue. Town council will only try to fix the leak and not any damage to your house.
If they tried all their usual methods to fix and still cannot find the leakage then good luck to you.
Our house carpentry, cornice all got damaged by the leaks.
Top few floors water pressure sucks big timeanw
tiagonk those top floor dwellers, the water flow (pressure) will be much more stronger than the ones below
but not until to that trickle level if 'cos
Yea top floorer
Now after HIP with the new clothes hanger (really dun like the design..sigh)... got small beehive which i cant access to remove... later mayb hv to call if the problem cant b solved
Not all top floor have higher ceilingwhy so special one?
