This one I think is depends on the water supply of the block. Some water are from water tank on roof top and top floors will have low pressure...some blocks get water from water pump from the pump room...no water pressure issue for top levels.anw
tiagonk those top floor dwellers, the water flow (pressure) will be much more stronger than the ones below
but not until to that trickle level if 'cos
My house top floor. Ceiling not hot (maybe because have solar panel)
Ceiling no leak , very windy , wait for lift not an issue , unblocked view .
issues I occasionally faced are lizards and teenagers at staircase smoking or do hanky panky stuff.
Given a choice again I will choose top floor, the higher ceiling height is good
i mean if they can access the rooftop to get to the water tank, they can die outside the water tank too.
but last time.. they build with TLC and construction materials are all good quality.
hehe..
Top floor has higher chance of pigeons resting and offering you continuous flow of jiao sai on your corridor and air con ledge.![]()
But stay below others might kenna corpse water? So which one is better?
nowadays with the installation of solar panels, heat may be reduced?i think top floor may be hot because the ceiling is expose to direct sun heat.
Why?
If built correctly, then no issue
Outside is of course algae.i do see top floor ledge area become green color. dunno is algae or bird sheet?
top-floorer reporting in
yes many lizards
Because roof top many insects to eat?
not extra hot at all
Why do you think top floor won't drink from the tank?But stay below others might kenna corpse water? So which one is better?
My hdb flat is on the top floor. Have to monitor rooftop water tank for leakage to my unit from the kitchen and bedroom ceiling.But stay below others might kenna corpse water? So which one is better?
Probably for the flats that are under 30 years old and the newer flat. My flat is 38 years old, completed HIP in August 2022.depending on the hdb design
i saw some the ceiling is not directly the floor of the roof....there is another structure so heat may not be an issue
Agree, but not near the common garbage chute. When fogging, cockroaches may enter your chute if you did not seal/tape it.Yes, stay top floor worst. Hot, water leak.
Best is stay ground floor. Not even middle
