knightshaz
High Honorary Member
- Mar 26, 2008
nikon need make retro z9 for him will look more normalHis size, the Zf looks like if I'd use a neck strap with Sony RX100
	you cake the paint ah look jin thicccbody head "done" liao
first time leh pang chanceyou cake the paint ah look jin thiccc
bo leh no time
water paints not so badMaybe also invest in a reusable respirator. Most times, your air purifier won't cut it
Wait smell too much lacquerlessson learnt so far
1. lacquer paint bky hand paint
2. lacquer paint very smelly
3. use primer
4. use spray can primer for sanity
5. thin that paint
6. wait wait wait
7. thin that paint more
time to go buy another sacrificial SD/EG
 next time cannot tape during CD then nose
 next time cannot tape during CD then noselet you smell ahWait smell too much lacquer
jiji shrink until becomenext time cannot tape during CD then nose
jiji speak from experience ahStay safe and don't get high and keesiao from the chemicals is can already
Better safe la, those masks with replaceable cartridges are okay - just feel a bit hot only, but with air purifier should be fine. After paint finish, leave in shower to dry cos less dust there (markersng lifehack)
Cannot tape is fine, but should don't leak & leave stains like Big Red Machine "Kurt Tay" Kane is essential
KorMarkersng lifehack, moi can attest to truth
Kurt one the image all over edmw mah - that xmm looking at camera and pointing wooden sword at the disgusting drip on Kane's costume
