Need advise on NAS storage
zephyr11
Ramelec
Popular NAS brands are Synology, Qnap and Terramaster.
Heard lastest model of Synology NAS only support Synology HD to get full feature support. Synology HD is very costly.
I am choosing one of this 3 brand
For home use backup
Now you said Synology HD is very expensive
I am looking for balance in performance and price and reliable
Which one?
Thanks
xonix
For home use backup
Which one?
Thanks
You can also check out asustor, some of their entry level models are fairly affordable too
Rogue
6 months later, still didn't get? lol.
Can go shoppee and look for Ugreen 4800 plus, 4 bay nas. It has its own OS, but you can install any NAS software you like, unraid, truenas ce and pretty good specs.
firesong
Deluxe Member
Ugreen seems to be the NAS to get now. Many long-time Synology users have boycotted Syno for their policy shifts that scream "cash grab". Asustor or Qnap are okay, but Qnap is a bit pricey.
If you have a bit of technical ability, consider building your own with TrueNAS. You're likely to get something much more powerful for not much more money.
purpleberry
What's the recommended cache size for Ugreen NAS or NAS in general? Should I get 2 x 1TB NVME drives? Or should I start with 1 x 2TB NVME first?
How about RAM size recommendations?
Rogue
4800dxp plus? Best to use 2 M.2, for read/write cache/raid 1 else it's just read cache only with only 1 M.2. Frankly 256GB or even 512GB is more than enough as cache, 1 TB if you have around 70TB or more worth of data (Basically 4x24TB HDD@Raid 5...).
Ram 8GB is fine. Add more if you are running a lot of VMs/containers.
purpleberry
Thanks. Going for 4x12TB HDD@Raid 5. Should be good for the next few years. Rest of the budget need to look out for a good UPS.
purpleberry
Those on Ugreen 4800plus, do you set your file system to BTRFS or EXT4 for Raid 5? BTRFS is set as "recommended" but there are those who said it is unstable and can lead to data loss.
leongws
I set it to BTRFS as it support snapshot
Ash
For Ugreen Nas, can I get from Taobao? The mobile apk is in English?
