Aiya I tell you all la..no need spend simi 100-200 buy simi satki jbl or jabra earbuds.
Just hoot qcy, anker, aukey or basus these kind can already.
好听就是好听. 不好听就是不好听.
Simple as that.
how is the sound quality?
can support spatial audio? dolby atmos?
pls share your reviews
The first series is really terrible, crackling noise even after exchanging 3 times, 4th time went down they refused to exchange.i only use airpods pro one..
Nowadays China brand quality is catching up maybe even on par with western brand
Told u liao all are oem from china factory just change design packaging and write until 有龍有鳳can sell expensive liaoI can hardly hear any difference.
Is all like dat now including those handheld gadget fans etci think just design then ask factories in shen zhen do manufacturing then sell with JLB branding.
Thank you bro. Added to cartYou guys want good audio quality and within budget, get the Moondrop.
Been using them for 4years liao.
Chu - Wire cheap
Space Travel - Budget got everything
Moca - Better audio than the Above
Robin - Honkai StarRail collap, damn good vocals, not so great bass.
Can go get the S$2000+++ one? Tell us the audio good anot.Thank you bro. Added to cart![]()
