LG 2025 TV discussion
eS.KuKu
Hello, what digital antenna you guys using for your TV? just got my G5, forgot no digital tv antenna. :rolleyes:
Amon86
I just got G4 for my new home few weeks ago
Amon86
How much did you pay? Why not 83G5 with way better tech (Tandem Oled)
around 7.8k for G5 is 8.9k i believe new tech is Early adoption there will be some problem as well.....mla has been around quite long shouldn't be a problem....if this tandem is been 2nd gen or 3 gen maybe i will go for that........beside i need to put aside some cash to upgrade my audio system
GotBetrayed
Thought I saw KEF kc62 sub. What speakers are you using?
Amon86
These are triangle comete 40th anniversary santos rosewood which i previously use them for my room at my parent's house....
i have other speaker like dynaudio contour 20i, bowers 805D3 as those are kinda heavy to move around so use this instead as is lighter for transport myself without damaging it......anyways i am going to upgrade to sonus faber sonetto G2 V once i upgrade my gears as well and speakers cable....then i maybe just use them as my new setup as computer speakers as now kinda budget after reno will only do so after next year
GotBetrayed
Bro too fierce man. Also saw Sonos in your pic.
I use Sonos arc ultra + 2 era 300 an 2 sub gen 3 for tv speakers for my LG 77C2.
music: KEF ls60 + 2x kc62 + Gaia II feet
Amon86
Mine only sonos arc the previous gen as i brought it 2 years before ultra....as i need it for my room new tv that time... i only had one sub gen 3 in my room.... heard ppl say the bass and vocal on the ultra is better... due to the new tech...the sub gen 4 on the another hand have like no much different other than the coating....
Kef LS60 with kc62 also a killer setup with gaia feet is also a good investment as i use those on my another setup focal kanta 2 and JL audio fathom 112v2 it makes the bass and soundstage wider
for music i mainly listen to my desktop i also using aperta stand like gaia effect
GotBetrayed
Now tc acoustic sale arc ultra is 1399 only.
yes gen 3 and gen 4 sub sound no diff.
our pc setup similar, I am using LS50 WII and Aperta. (Also with kc62 sub). Another pc setup is LSX II and KC62 + KEF feet
I have 2x LS60 setup with dual kc62 and Gaia II.
regarding Sonos… I have 2 more arc setups now.
1x arc with dual era 300 and dual sub gen 3 paired with my 65G1 Oled tv.
1x arc with sub gen 3 + 2x ones paired with my 65GX Oled tv.
Amon86
wa...you also have many setup like me....one will be never enough lol....i thinking for my new bedroom kef xio...but i see review like now having a lot of issue on connectively
GotBetrayed
Don’t think it’s worth to buy XIO, KEF is never good at soundbars. Sonos still dominant in this area
btw think your monitor is AW3225QF same as me. My other setup is XG32UCWMG, got 2x AW2725Q too.
Amon86
Ya that's right, you had sharp eyes in spotting stuff that's my first oled before i brought this LG G4 previously all my display using mini led as scare burn in issue....but after using oled you know lol
GotBetrayed
Hahaha, miniled is thrash vs Oled. Waiting for 32 inch 4k240hz tandem Oled to replace my AW3225QF.
Amon86
I getting this for my new study room as i wanna try ultra wide as my parent house my computer space is limited if i put ultra wide i must sacrifice my audio.....
I know there is another model LG 45" 5k/2k monitor but that need killer graphic card to run it....don't think 5080rtx can make full use of it......
GotBetrayed
Too fierce bro. Yea I have 2x 5080/9800x3d and 2x 5070ti/9800x3d setups.
I need to get 83G5, but Oled prices for 77/83 should drop over the next few years. Now it is much easier and cheaper to produce compared to before. However, no rush for me as I’m quite satisfied with 77C2 and sitting about 2m away. Not sure if 83 inch will be too close for my viewing distance
Amon86
I see i using 83" with 2.5m away from it.....actually wanna get 77"G5 as is cheaper than the 83"G4 by few hundreds but after thinking about it....still got the bigger one as i use to bigger screen liao i got a 100" projector screen for home theatre and my room 75" so aiya get bigger one
GotBetrayed
Ya bigger is always better. Hope lg launch 88 inch size or something. 97 inch too expensive at the moment. Would say if 97G5 is around 12-15k, still ok.
Botakkid
any idea if the G5 will go cheaper on 11.11? still holding on to an order for G4 at $3080, saw G5 on sale at 3.2k+ after all the vouchers at MEGA store on shopee with free $200 grocery voucher during 10.10 period, but now price increase already, after did all the calculation with the free grocery voucher, the G5 was only $90 more than the G4 only
still waiting for my house to be ready before asking for delivery, if G5 can go cheaper then will probably give up the G4 and take G5 already
GotBetrayed
just go G5 already. Don't bother with G4
