Johor Bahru - share is caring - Part 2
  • Have you been Scammed?
  • Need someone to talk to?
SantyBalls
Nowadays I will recycle the 15 eggs boxes and bring to transfer the purchase eggs into them.
Sure no breakage.
You damn lucky your eggs shells weren’t the thin ones.
Always hold up tray of eggs and check that the bottom of tray shows no trace of broken eggs
Too much effort. Just bring a row of scotchtape.
At ksl they even tape for u
sunsetbay
Moderator
Moderator
Speaking of 鸡蛋不会破,
Tape like that never break any eggs b4.
If lazy tape, can just put in this kind of bag.
I once didnt orientate the egg tray properly, end up eggs slide all over the place. Heng ar nvr break.
Sure no breakage.
No such problem at NSK trading center at Pandan, they tied their egg trays securely~ however the other NSK branch at Skudai dun have such practice~ :s22:
SantyBalls
Dont look secure. If put vertically in backpack sure gg.
Also the law is 30eggs/person. But so cheap the eggs.
Earlier this mth this was the price at ksl
A: 65g
B: 60g
C: 55g
Ck: 55g
D: 50g
A, $14.05
B, $13.45
C, $12. 69
D, $12.09
tiertime
I only buy eggs in KSL 2x
1st time variety was very limited, 2nd time was I gave chance 😂
Then after tat when Im there I rather walk 10mins to Taman Pelangi area to buy frm the eggs supplier , they hv the ones I prefer there like those 30/ tray kumpung eggs
Half a year nvr go KSL le , too crowded....
SantyBalls
Expensive.
SantyBalls
divide by 30 , it will feel cheaper
A is still cheapest
Eggs are graded by the weight of each egg:
AA: 70g
A: 65g
B: 60g
C: 55g
Ck: 55g
D: 50g
Below are the prices for a tray of 30eggs. Which is the most worth it?
AA, $18
A, $14.05
B, $13.45
C, $12.69
D, $12.09
Step 1: Calculate the total weight of each grade of eggs per tray
For grade AA eggs, total weight = 70g * 30 = 2100g.
For grade A eggs, total weight = 65g * 30 = 1950g.
For grade B eggs, total weight = 60g * 30 = 1800g.
For grade C eggs, total weight = 55g * 30 = 1650g.
For grade D eggs, total weight = 50g * 30 = 1500g.
Step 2: Calculate the price per gram for each grade
For grade AA eggs, price per gram = $\frac{18}{2100} \approx 0.0086$ per gram.
For grade A eggs, price per gram = $\frac{14.05}{1950} \approx 0.0072$ per gram.
For grade B eggs, price per gram = $\frac{13.45}{1800} \approx 0.0075$ per gram.
For grade C eggs, price per gram = $\frac{12.69}{1650} \approx 0.0077$ per gram.
For grade D eggs, price per gram = $\frac{12.09}{1500} \approx 0.0081$ per gram.
Step 3: Compare the price per gram for each grade
The lowest price per gram indicates the best value.
- Grade AA: $0.0086/g
- Grade A: $0.0072/g
- Grade B: $0.0075/g
- Grade C: $0.0077/g
- Grade D: $0.0081/g
Grade A has the lowest price per gram.
The final answer is: $\boxed{A}$
tiertime
But usually ppl dun calculate until like this when purchase eggs, unless doing business
We buy for own consumption so we dun use the cheapest eggs , I need to eat slightly expensive eggs , will feel happier 🤣
SantyBalls
You don't understand how fast eggs use finish in my household. 30eggs a week not enough 1.
Anw normal n kampong feels all the same to us. Don't really find kampong eggs are worth that extra 4rm.
If grade d cheapest i just buy all grade d.
sunsetbay
Moderator
Moderator
A: 65g
B: 60g
C: 55g
Ck: 55g
D: 50g
A, $14.05
B, $13.45
C, $12. 69
D, $12.09
I bought the Grade A eggs for RM 11.50 earlier this week~ Grade B was RM 11.20, which made Grade A more value for money~
I did weigh the eggs at home and compared to Grade B eggs I bought previously at lotus~ A is significantly bigger~ and compare to Fairprice pasar eggs, it's like mini size compare to grade A~ :s22:
SantyBalls
Wa ur grade a is grade d price at lotus lol
Which nsk got good things nearby? Like food, breadshop, etc. Thinking go permas/johor jaya area ltr 🤔
sunsetbay
Moderator
Moderator
For food option, there's a McDonald's and the food court in MidasMart, which I'd shared before~ NSK building itself have fast food restaurants but not appealing~
it's quite near to Mt Austin and Aeon Tebrau though, other than that there's no walkable shop houses like KSL~ :s22:
https://maps.app.goo.gl/itatW5SbnbyDcdZv5
Inside NSK building~
Roastduck
This is the jb Columbia hospital that I stayed Precovid. This video gives more info on jb Pte hospitals care n costs
SantyBalls
SantyBalls
