pokipoki08
- Aug 29, 2008
using redmi buds 5 which sounds better than redmi buds 5 proeh any sites to get good test high quality music for Anker liberty 5?
supposedly can do ldac
got it for the 52db noise cancelling la cause my realme buds air 2 pro neo getting quite unreliable to stay charged for trips.
dunno is placebo or not for the extra 22 db and intelligent NC.
again get because some people on the bus so loud
i confess I use more for Spotify, audio books , tiktok and youtube la.
Read HWZ Forum Rules!
bought the wavelet app, 9-band EQ, equal loudness, limiter, bass tuner, good quality overall, some earbuds profile are supported
https://play.google.com/store/apps/details?id=com.pittvandewitt.wavelet
use youtube sound frequency test to identify and tune eq accordingly
source material matters the audio bitrate minimum 192k lossy m4a (aac) or webm (opus)
https://github.com/deniscerri/ytdlnis
this downloader allows selection of higher bitrate from many sites
use SPEK program to check bitrate authentic or not, this is definitive
while https://mediaarea.net/en/MediaInfo shows variable or constant bitrate as reference (tracks as mp4)
youtube and bilibili can find >192k tracks
if equal loudness across tracks matters the only fix for me is ffmpeg loudnorm (command line re-encode)
