Looking for recommendations for table top speakers
midlusionz
For $200, get edifier and u are done with it. If you can increase budget to $500 Kali audio LP-Unf. Can go to Nihilo at Adelphi for demo. They are open Fri, sat and sun 1pm to 7pm
Tortoise79
Hi, is there a desktop speaker that has a 3.5 mm AUX input and a headphone outlet on the front of the speaker? Price range around 200 to 300 ish.
The_King
Honestly, if you willing to spend up to $600, get a pair of Eclipse TD307MK3. You can buy from Amazon JP ship direct to Singapore. A pair will set you back 60000 yen including delivery. Add a cheap Topping or SMSL integrated and some speaker cables all together should be less than $600 SGD. I guarantee you this combo will be better sounding than any of the options listed above. These are true audiophile grade speakers and can be the start of a very very deep rabbit hole.
If want to buy locally, can buy from Audio88 from Adelphi, though obviously a bit more ex.
this one currently 26000 yen, and me currently using b&w 685 s2. any good replacement?
around SGD800 +++ ----
thinking of replacing my 11yr old speaker
using smsl AO 300 pro, bluejean cable ( Belden 5000UE ), some atas thick usb c cable from TB
thanks
