Desktop 2.0 & 2.1 speaker discussion thread VI [consolidated]
GotBetrayed
So many kef, you’re certainly the number one kef guru here.
No la I only use wireless series.
2x LS60 with 2x kc62 each and Isoacoustics GAIA 2 feet.
LS50 wii with kc62 and isoacoustics Aperta - pc desktop use
LSX II with kc62 and KEF feet for desktop use
boxerfan
Have been wanting to hear the Blades, managed to do so @ WAVE show a couple of weeks back.
These Blade1 META sounded good!
The_King
reposting to here
me currently using b&w 685 s2. any good replacement? thinking of replacing my 11yr old speaker for desktop setting as pc speaker
prefer to spend around SGD800 +++ ----
using smsl AO 300 pro, bluejean cable ( Belden 5000UE ), some atas golden plated very thick usb c cable from TB
thanks
boxerfan
I have been following AsciLab's development. They design extremely well measuring speakers. They use Klippel NFS during speaker development. Their driver & crossover components look to be pretty high quality. Demand is high, they are perpetually out of stock.
For your $800 budget, I would recommend AsciLab F6B. If you can stretch your budget a bit more, shoot for the C6B.
https://ascilab.com/category/f6b/68/
Go watch Erin's Audio Corner review of the C6B.
I think they have signed up a SG dealer, you may wish to contact them directly.
yapks
yapks
It’s likely that KEF lacks the high-end extension and bass output of B&W, but its strength lies in the cohesiveness of its coaxial design for near-field desktop applications. Subjectively, it may or may not feel like an upgrade, depending on your preferences.😁
The_King
ya my 685 is too near, if i was about 30 to 40cm away from my computer desk it would sound a lot better as in sweet spot
that why now want to change a bookshelf for desktop.
since this is for near-field desktop applications should sound a lot better
cherryboom
just change out my B&W 685, nad 326bee and asus essence one dac that i have been using it for years just because a sudden random itch.
yapks
Wow, the 3i—very cool. I love how isobaric designs deliver such tight, controlled bass. I auditioned it briefly once—wonderful speakers.”
