Got a lot of modelshi what is this Hasivo u switch u mentioned? From aliexpress?
Can i have the model please
I buying from here: https://a.aliexpress.com/_c4k4hzlr
I am planning my house 10GBe infra now, am thinking to get two Asus RT-BE88U (one in living room, one in my room that also happen to be furthest from optical point) to replace Orbi 1st gen. Will do wired backhaul
Good idea or got better options?
Can it pass by more than 2 walls? If going with this approach, will need a really strong model that can do well with walls cos so far what I am seeing is that I need a mesh setup to overcome those wallsI'm using an ASUS GT-BE98.
https://rog.asus.com/sg/networking/rog-rapture-gt-be98-model/
It comes with dual 10G Ports.
1 can be used for WAN
1 can be used for LAN.
Previous router was ASUS AC-5300.
My philosophy is to use a 1 router non-mesh simple setup.
Those ASUS Monster Routers with 8 antennas are more than adequate for providing high speed wifi to every part of the house.
For my current GT-BE98, I am getting wifi speeds of 600 Mbps from bedrooms.
Direct sight wifi speed is 900 Mbps and close to 1 Gbps.
Yes, the router’s wifi signals are strong enough to cross over concrete and wooden doors.
You can also refer to this video review over here.
The reviewer was getting over 600 Mbps WiFi speeds outside his home.
Definitely can penetrate multiple layers of concrete and what not .
Thanks!
Ok guys, I just grabbed the BE98 from SLS just now. Figured that if I wanna upgrade, do it right and get flagship model to test first hahaha
(my wallet crying though)
The old AX11000 series already can receive connection from 4 floor to the ground floor with it near the window from my experience.The feeling I get when I returned to an ASUS-Merlin based router after almost a decade
https://c.tenor.com/dBC9qb2cyxcAAAAd/tenor.gif
And good lord, the GT-BE98 is a beast in many ways. Even my room, separated by two thick concrete walls, can receive 5GHz signals but around 2 to 3 bars instead of full coverage.
Not bad, will keep testing and reporting here
ngl actually I am starting to think this is legit good idea cos those Chinese Topton/CWWK 10Gbe pfSense machine a bit more expensive than UCG Cloud Fiber it seems. Learning a different router OS will be the main challenge I think?UCG Cloud Fibre + U7 Pro XG/XGS, don’t look back liao.
You can use GNUton's builds, a Merlin fork.Have to rollback from Merlin to 3.0.0.6.102_39115 (which is what was shipped with my router); sounds like there's quite a bit of improvements from stock firmware that is yet to be in the general release version of Merlin
Also noticed the lack of ability to set AES/TKIP+AES etc for wifi password in Merlin and generally weaker 5GHz performance
EDIT: Ugh, really hope Merlin is updated; the stock ASUS firmware as a router feels too limiting and bloated at the same time to me as a current pfSense user. At least it can work as a router in case I need fallback options and somehow it can get Starhub's IPV6 without issues. Will most probably use this GT-BE98 as a wireless AP while letting the pfSense machine remain for DNSBL/routing duties
That's the build I was using before having to rollback; only this build works with BE98 cos Merlin can't make for BE98 since it is not sold in the US
Can I check if getting Asus mesh from Europe will work in Singapore for the WiFi bands?
Sian, looks like ultimately I need a satellite unit for my room.
So far only my room will have much significantly weaker wifi even with BE98 cos of how the wifi signals travel through two walls compared to all other rooms
What do you all suggest for an Asus Aimesh satellite unit?
