[Official] Amazon Prime 2025 Deals
yukita
If you need the DDR5, just bite the bullet. Prices will not come down anytime soon.
My current config is 2x16GB crucial pro 6000 cl 36. wanted to upgrade to 64gb kit. i saw 32kit 7200 cl34. it does not have to be 6000 cl30 right?
Koenig168
You can mix RAMs and then try to find the most stable speed and timings. However, Ryzen does not work well with 4 sticks, especially different ones. You might have to lower speed and loosen timings quite a bit to get things stable.
In any case, that G.Skill RAM is a waste of time. You can try placing an order, it will be cancelled a few minutes later. (I tried 4 times.)
koohansen
If you mix, the RAM will run at CL36, match it with the same speed for stability. As long the RAM you purchase has higher speed and lower CL values its fine, but not recommended to mix different speeds.
yukita
I thought only i have this issue.
Noted.
Stick to your DDR5 6000. 7200 more for intel than AMD.
the ram is specifically for AMD EXPO only, not even mention Intel XMP.
alternatively looking at 64gb ram but at lower speed 5600 with cl40. the performance different should be less that 5% compared to 6000 cl30 from what i understand. any concern if the preference is on higher capacity than faster speed? does it difference more than 5% assuming i understand it wrongly?
deepblue_82
What do u guys think of this Chromebook... can get? Has Google updates up to Jun 2029...
https://www.amazon.com/gp/product/B0851KK23N/ref=ewc_pr_img_2?smid=A5W45QDYAHWB2&psc=1
throw.....
i used to use a netbook... its very much similar to the current chromebook...
the os may said to be light..... but very soon u will feel the age of the "chromebook"
pay abit more get a under 1k laptop, u can watch LTT they also did a comparison a chromebook and a norm laptop..
i have really been there really dont waste ur time with this chromebook...
8-lane
I see... was ur netbook also on Chrome os?
limcc
Sennheiser Open Back Headphones HD 599 Special Edition S$111.03 from AmazonGermany or S$143.74 from AmazonSG
8-lane
KleoZy
those who need, grab lor. btw 6PM $12 dollar voucher
For prime member SG
Redeem
Get 10% Off with UnionPay. Enter code CUPBFS at checkout. Discount Provided by Amazon.
Redeem
S$10 off S$200 with PayLater by Grab. Enter code GRAB10 at checkout. Discount Provided by Amazon.
Redeem
Get S$10 Off with HSBC Credit Cards. Enter code HSBCBFS at checkout. Discount Provided by Amazon.
Redeem
Get S$8 off S$120 with Atome. Enter code ATOME8 at checkout. Discount Provided by Amazon.
G.SKILL Trident Z5 Neo RGB Series DDR5 RAM (AMD Expo) 32GB (2x16GB) 7200MT/s CL34-45-45-115 1.40V Desktop Computer Memory U-DIMM - Matte White (F5-7200J3445G16GX2-TZ5NRW)
S$216.64
https://amzn.asia/d/dhmBXOw
Credits to a very good friend @Reavl, who have shared this info
For the fun of sharing. his artwork
yukita
For prime member SG
Redeem
Redeem
Redeem
Redeem
S$216.64
anyone successfully order this ram, update here :s22: I ordered and it was cancelled within minutes.
