Xiaomi Pocophone F1
kazuki666
I am still using this phone, but as work phone. Honestly I need to change soon. The power button is compressed cannot use already. Battery is quite bad. Maybe a budget Poco with 5G good enough
Devilsire
Hi hi,
easy to change the power button mah? Mine also hard to press le, wanna repair it
Wahh moi also just kena haha moi read some say it's the rubber disintegrated but might be other issue too
yes i changed before, its the button's rubber part being disintegrated
quite easy to change, just need the tools (iirc some screws are of special heads), can refer to youtube
just be more careful when handling flex cables eg. the one connected to fingerprint sensor on case and the one at power/volume buttons
chaiscool
Hi hi,
Update, change power - volume button and it works. Yeah the previous one the rubber disintegrated liao.
Easy to do, hardest part is putting in the new button and moi had to use scotch tape to hold it so can close the phone casing. Super easy, it's only 2 t3 screw at the bottom, remove sim card slot and moi use credit card to open the screen - casing (careful not to rip the fingerprint cable as the 4 edges a bit hard to open using CC).
Lazada got voucher so moi paid $0.60 for the button and the extra optional sensor, shipping is $2 though. Wanted to change the battery but cannot find non sus ones on shopee or lazada. Alixpress shipping quite ex too. For battery imo go mistermobile pay $38 can liao.
dreamcast18
amazing - what android are u running on it?
