Oppo Find X9 Series
Shadowz1984
i apologise about linking back to xiaomi, but i personally felt that oxygen updater comment is targeted because you just drop it out of nowhere
It's just a general comment from my usage experience of oxygen updater.
tkte_85
ok. i understand u talking about ads in general, but i am specifically talking about system apps that i have issues with. So for me i also wun recommend realme coz its the same situation about the system app ads
Shadowz1984
For me, I will generally avoid apps with ads unless die die no choice have to use. HWZ I am viewing via mobile chrome, don't really have ads pop up. I know when using at desktop, the ads keep popping up, damn irritating. Anyway, I apologise for bringing up the Xiaomi topic over at OnePlus page few weeks back.
chari-men
Huh
I tot activate in sg liao but disable first
Then go there liao then enable can liao right
If not then use their airport wifi to activate lor
Ya u need internet to activate... Usually in airports lo free wifi..you disable or not doesn't matter coz it's only usable in your designated roaming areas..
tkte_85
Huh
U still haven tell us which esim u using. But usually is just download the sim profile 1st, the company's esim would have registered the esim with your phone's esim IMEI alr. Then when reach destination turn on can alr.
At least that's what I did with my ByteSim with Japan unlimited data, but I put in my 5ber sim card in the app, even though I have esim in my phones, coz my simba esim stored in e same app/sim also has intl roaming so can switch between the 2
hstreamy
How do I add esim overseas? Is it once I scan the esim Qr code liao, then under eSIM menu, I must select 'enable' under the 3 dots when I reach other country?
Side track a bit...recommended for those needs esim when overseas. Using esim from ICC,good signal strength.Worth to give it a try.
Btw,Simba roaming in Shanghai kinda sux at times.
masashi
It's finally here :love:
