Oppo Find X9 Series
JoblessDad2023
Hi guys, current S23U user here.
Look around for quite sometime already and decided that X9 Pro will be my S23U replacement.
Other than the standard pros and cons, anything i should take note coming from the samseng camp?
masashi
Curious guys, can the Oppo Find X9 Pro use downloaded icon packs on the Google Playstore?
No issues at all
Jurong640
I'm also from S23 Ultra. But quite a number of us deflected to Vivo X300 Pro, and a few to Oppo X9 Pro.
Things to take note:
- if you got lots of samsung notes, you can't migrate over. Google Keep app is cmi.
- Some password you keep in Samsung Pass cannot be migrated, you have to save the password on your chrome.
anthonygreenisreal
No regrets the camera downgrade uh? Didn't know OP15 is lighter than X9 Pro
The OP15 camera looks fine to me.
OP15 is around 10g to 15g or so lighter than the Find X9 pro.
if you hold them in hand long enough can feel. Put inside pocket can also feel the weight difference.
standarture
I also using a s23u. Wasnt planning on changing but kenna youtube rabbit hole. No regrets though. Battery life is awesome. Even at 30% left, I went out for dinner with no anxiety. Camera is definitely an improvement. UI is smooth and snappy. Phone seems twice as powerful from benchmark scores. Personally didnt really encounter much cons so far..m. Battery seems to charge really slow at the end, slower than my s23u for sure. Most are user dependent, like for me google timeline is a bit slow to save changes.
