did hdb come check your distribution board......
mewmew
but never replace it.....forgot wat they check for?
wayang ish it
Apparatus
You distribute mewmew porn siboh? :LOL:
iu
iu
mewmew
how to initiate the replacement ah any channels? dunch noe waddaf dey check
Apparatus
NintendoSwitch
Got some official notice some time ago.
All homes in Singapore must have residual current circuit breakers installed from July​
Homeowners will be given a grace period of two years from the required date to install the electrical safety device. “
Source: https://www.channelnewsasia.com/sin...-1-ema-hdb-flats-private-housing-1985-3480786
What is Residual Circuit Breaker for those of us who don't speak Civil Service or electrical engineering?
Ethan_
accucore12
they just checking whether you met the requirement. they got send pamplet last time to inform u by 2025 need have rccb installed.
How long did they check it and did they say anything to you after they check?
jeff79
All old ELCB to be replaced with new RCB/RCCB
Heng. Mine replaced a few years back
:D
Wrong. Read the news posted in post #7. HDB wants hdb units built before 1985 without elcb to install rccb. Before 1985 hdb units were provided with only fuses to protect against overload.
As long as your unit electrical distribution board box has functioning elcb do not need to change even if 40 years old.
This is the answer by ema.
https://ask.gov.sg/ema/questions/cli41mb3n001ijr0fsfy9favw
jeff79
Rccb is safer method of detecting electricity leakage. Elcb detect leakage into the earth wire only. However electricity can leak from human body onto floor or appliances without earth wire. Rccb detect leakage by the tiny difference between the live and neutral wire.
In some countries elcb is actually rccb. Need to determine what is the circuit breaker trip detection method.
mewmew
dey do onsite check based on the mentioned point
