- Jan 7, 2007
Thanks for the quick replies.EV charging requires a dedicated 32A source in order to get the 7kwh for single phase chargers. Normal 13A power point cannot be used and is illegal not to mention it is a fire hazard. So if your point is already 32A with an isolator then it’s fine. Else if it is a shared point then you cannot use it due to risk of trips. If it is a dedicated 13A point, you could still use it if the internal cables are at least 2.5mm2 sized. Then you just need to change the 13A socket to an isolator and confirm the breaker inside the DB is suitable. But then you will have to run your charger at reduced rate of 3.5kwh which is a current draw of 16A only.
I did set aside one with an isolator, later on, I took out the isolater to fix a cabinet, haha. But there is a line with a normal socket that I hope does the job..
Toyota is actively trying to reclaim their crown, so if anyone is in the market, google BZ4X and see if it fits you..
